Thread: Wheel stud replacement.
    Senior Member iam99x's Avatar
    Athens
    Default Wheel stud replacement.
    I have a broken stud on my front left hub, I already have a replacement stud. I disassembled everything only to find out that there is no way to remove the broken stud without taking the hub to a machine shop. On other cars, I have noticed that there is a cut-out that you can line the stud up with to remove, is it unsafe to cut out a little 1/2" half circle that would allow me to remove the stud?
    Thanks.
    Senior Member EJdm's Avatar
    what kind of car??
    Super Handling
    Use a slide hammer to remove the hub.http://honda-tech.com/zerothread?id=907985&page=1
    Gainesville
    if it is just a regular car you an take a hammer and beat it out. then take it put the new oneback thru the hole and take a air impact and tighten a open end bolt and tighten the sum ***** tight as you can get it to pull it back thru. that would be the usual way to do it. i've done it about 5 or 6 times for friends and a bunch for my own lol
    just did mines the other day..i used a slide hammer, afraid i mite have ruin my bearings
    Athens
    94' Integra. I'm going to try the slide hammer trick, although I'd like to change it without taking the hub off. So I was asking was it safe to cut a small 1/2 circle out of the part that blocks to head of the stud.
    One of the very first things my instructor told us was to never put the stud through, then tighten it down. I really can't remember why, but it's not safe from what I've heard. But, that's probably what I would have done if I didn't know better.
    Thanks guys.
    RWD FTW. 0DISPLACMENT's Avatar
    flowery branch
    i just replaced all my front studs. its easy if u take the hub off. (takes like 5 minutes) and just hammer the **** out of it. then just press the new stud in. if u dont have a press then try the nut trick
    Athens
    On a Honda?
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    Quote Originally Posted by iam99x
    Thanks guys.
    i really dont see what it would hurt using the nut trick, i've done it a bunch of times as well and yet has it bit me in the ass. however the cutting idea doesn't sound like a good idea or safe. but hey who knows you might have figured some new trick out
