Thread: b18c1 question..
    FTP!! GSXR dude 95civictypeR's Avatar
    Henry
    Talking b18c1 question..
    I have a gsr. i have a blown head gasket and im replacing the pistons while im doing all of this but im getting the block honed out what pistons should i go with? i want it turboed later down the road. but right now i still want it to be some what quick.
    Guys: No Shirt, No Service
    Gals: No Shirt, No Charge
    BOOST Gets U LAID
    Cedartown
    Go with either JE, CP , Arias 10:1 if u plan on running it na for a while if u go low compression then until u turbo it it will be a dog.
    everywhere & nowhere
    83.5mm CP. Go 9.8:1 CR, def no more than 10.0. A 10.0 motor will still be decent off boost, and still be fairly fun until u add the snail. What are you doing for rods?
    Henry
    im not sure yet.. im on a budget.. but i still want it to be fast..
    Then get some used/new Eagle H beams. U need to have your entire plan on paper before you start tearing down the block man. Little things like new oil/water pump (and gears), head studs, head gasket, honda-bond, misc shop tools, bottom end gasket set, will set u back.
    Don Mon SiRed94's Avatar
    Morrow 30260
    if you are changing the pistons you have to take the entire bottom end out and get it balanced ... (crank, rods, pistons, etc...) if you are on a tight budget keep the bottom end stock and be satisfied with 10 psi of boost.... you will still put down 260-280 whp... even if you get pistons and rods and balance... i still wouldn't go past about 15 psi with stock sleeves.... if you are on a budget just do a stock rebuild and save the piston/rod money for tuning...
    Henry
    ya i like that idea.. but it is easier doing it while its out, but then again..
