Results 1 to 14 of 14
Thread: halo headlight wiring
    SOHC my DOHC Meso Teggy's Avatar
    Atl
    Exclamation halo headlight wiring
    ok i just purchased a pair of halo headlights for my ride i wanted to know how do i wire it so that the rings light up with the parking light and also when the low beams are on? i tried searching for an article but had no luck....here is a pic of what im getting thanks in advance to whoever can help out
    Duluth, GA
    can you tab the wire from the parking light? I think it should work.
    Shine on! Nittanys1's Avatar
    Raleigh, NC
    ^ YUP, you just need to find the wire that lights up the parking lights.
    Atl
    thanks guys meso appreciates the help
    Gainesville
    or you could wire up a switch. thats what i did also im gonna go ahead and warn you. you need to put extra sealant on them because they tend to leak a **** load
    Gainesville
    also in my opion don't rice it out with those man get you some oem projectors witht the jdm dc front end and get some clean HID's ftw
    Raleigh, NC
    if you wire them to a switch then you have to run more wire :d you could splice the wires that goto the parking lights that are in the engine area and not have to run wires into the cab.
    Gainesville
    i liked the sitch cause you could keep them on when you turned everything off. i thought that **** was wicked looking if you went that route
    Raleigh, NC
    yeah your right that is a good plus!
    Gainesville
    hehehehehehe
    Gainesville
    also on a side note i hated the ones with the lines in te halo imo looks like a cheap plasti like i like the one that looks like clear acrylic
    e36 noob 2shroom's Avatar
    nice i thought only bmw's could have halo eye things.
    Raleigh, NC
    y would you think that? anything is possible...if I can put projectors in my headlights he could easily to this to his without buying them pre-made...
    Atl
    yeah so i just got my halo's...they look nice....they dont look as cheap as i anticipated...here are some pics....ummm one question the halo wires are those two red ones right? i know im supposed to connect one wire to the parking.... the other one goes to the ground right....i know the ground wire is black what color is the parking? and those two wires it doesnt matter which one goes to which?....thanks in advance
