Results 1 to 22 of 22
Thread: FS / FT: 1991 Toyota MR2 Turbo w/ Bad Block + Spare Block + Mods! *OMG SUPER-CHEAP*
    NalleyToyota Manager ct9a gsr's Avatar
    Kennesaw, Ga
    Smile FS / FT: 1991 Toyota MR2 Turbo w/ Bad Block + Spare Block + Mods! *OMG SUPER-CHEAP*
    Make: Toyota
    Model: MR2 Turbo
    Year: 1991
    Chassis Mileage: 145,xxx
    Motor Mileage: 35,xxx
    Engine: JDM Celica GT4 3SGTE Turbo Motor
    VIN#: For Serious Buyers Only
    Title: 100% Clean Title
    Performance Modifications:
    - 1994 LSD Transmission (NO GRINDS, Great Gearing!)
    - APEXI N1 Exhaust
    - RACETEP 3" Downpipe
    - Test Pipe
    - Centerforce Stage 1 Clutch Kit
    - HKS BOV & Flange
    - Top-Mount Intercooler
    - HKS Intake Adapter
    - 1994 MAF Sensor
    - Port & Polished Intake Manifold w/ TVIS Delete
    - 3" Custom Intake
    - Thermostatic Temp Control (for fans)
    - NGK Laser Platinum Plugs
    - Blue Ground Wire Kit
    - Ported Throttle Body
    Mods Installed @ 130,xxx miles:
    - Newly Rebuilt Stock CT26 Turbo
    - New Alternator
    - New CV Shafts
    - New Spal 10" Fans
    - New GM Knock Sensor Upgrade
    - New Starter
    - New Battery
    - New Toyotal Timing Belt
    - New Water Pump
    - New Throwout bearing
    - New Twos R Us Brass Shifter Bushings
    - New Oil Pan Gasket
    - New Valve Cover Gasket
    - New Distributor Cap
    - New Coils
    - New Igniter
    - New Intake Manifold Gasket
    - New Exhaust Manifold Gasket
    - New Turbo Gasket
    - New Rotor Button
    Suspension Mods:
    - R1 Drilled & Slotted Rotors
    - TEIN Lowering Springs
    - Bendix Titanium Brake Pads (all around)
    Exterior Mods:
    - 16 x 7.5 Silver Fittipaldi Polaris Wheels
    - 205/40/16 Dunlop 9000 Front Tires
    - 225/45/16 Dunlop 9000 Rear Tires
    - RayBrig H4 Headlight Conversion
    - Eribuni Rear Side Engine Vents (not installed but will come w/ car)
    Interior Mods:
    - HKS EVC Boost Controller (Mounted in Center Console) Activated By Switch
    - Isotta Black Steering Wheel
    - Sparco Chrome Center Ring
    - Sparco Steering Wheel Hub
    - HKS Turbo Timer II
    - HKS Turbo Timer Harness
    - Old School Sony CD Player (Plays CDs Great, but AM/FM isnt to clear)
    - Black Leather Shift Boot
    - Megan Racing Short Throw Shifter With Lowering Plate
    - FAZE Reverse Indiglo Boost Gauge (In Dash)
    - FAZE Air Fuel Ratio Gauge
    - FAZE Single Pillar Gauge Pod
    - Reverse Indiglo Gauges
    - Carbon Fiber Gauge Cluster Bezel
    - Stainless Steel Switches, Custom Aluminum Brackets and Push Buttons
    - Quest Aluminum Pedals
    - Power Windows & Power Locks
    - Black on Black Leather
    Problems / Issues:
    - Crank is locked up and will not turn... assumed to be a bent rod
    - Paint has several imperfections (uneven pits and waves in sanding) when looked at up close... mostly on the hood which a CF hood should fix
    - Door has a couple of dings, nothing major or not typical of a 16yr old car
    - I'm not sure how the in-dash switches are wired up, sorry
    - 16yr old OEM leather driver seat has cracks
    - Needs a shift knob
    - Driver's side mirror is cracked
    - front lip has a dent
    - muffler tip has a dent
    THE CAR WILL COME WITH A SPARE 3SGTE SHORTBLOCK
    The car is was originaly a turbo model and the OEM motor was swapped out with the All-Trac GT4 3SGTE by a previous owner. The motor is the JDM Celica All-Trac GT4 version of the 3SGTE. The difference is in the compression (8.5:1 instead of 9.0:1 like others), the camshafts (something about the duration?), and none of the emission crap like EGR or extra sensors (Oil Level, Crank Angle). The car ran a 12.92 @ 111mph spinning in 1st and 2nd gear by a previous owner on the stock turbo @ 15psi w/ the top mount intercooler. This car beat my Evo from a roll when I had around 300whp. Factory MR2 fuel, ignition, and motors are built to hold 300+ horsepower without any upgrade. Factory injectors are 440cc and there have seen well over 400+ horsepower on bone stock blocks.
    I purchased this car from a personal friend of mine with intentions to get it up and running to use as a daily driver. However, I've lost interest and do not have the time to get this car up and running. I am in need of a daily driver... the sooner the better, hence why this project is up for sale. I bought the car knowing the block is bad however, THE CAR WILL COME WITH A SPARE 3SGTE SHORTBLOCK! Clean the block, mill the head, install new headgasket, and maybe a new oil pump (optional) and this car will be back on the road.
    This car was up for sale late this summer and I have a LOT of interested buyers... however, I barely had any time to show the car to people AND I had way too many flakers wasting my time. I haven't had time to do anything 'til now due to school. So now, this will be the first of my cars that will be sold.
    Asking Price: $3,500 OR ANY TRADES, JUST PM ME!
    I will ENTERTAIN ANY/ALL TRADES THAT ARE REASONABLE! THIS INCLUDES A CAR + MONEY ON YOUR OR MY PART!
    Several Pictures:
    I will post more pictures later but feel free to come check it out in person!
    770-912-4009 or PM me
    -Charles
    www.toyotaofroswell.com
    Current: '04 S2000
    Past 700whp+ Cars: '03 Z06 | '94 Supra | '03 Evo VIII | Too Many...
