Results 1 to 20 of 20
Thread: d16y8 w/Boost...what psi on stock block?
    DC5-R
    Gwinett
    Default d16y8 w/Boost...what psi on stock block?
    wondering how much can a stock internal y8 take? will be daily driven.
    also, is 200whp obtainable? as far as tuning goes, I got that covered.
    And last would 330cc be too much? or should I go smaller...
    330cc is too small, you need 450cc at the minimum
    9-10 psi PROPERLY tuned is about max.
    it should make 200whp easily
    DC5-R
    Gwinett
    really? I thought 330cc was good up to 270whp. I was mainly trying to see what it makes with 7psi spring. And also is a fuel pump necessary for the route I'm taking? just looking to obtain 200 or so without a large headache.
    140 on one wheel
    columbus, ga
    your good for about 230whp or so. no more the 245whp. If your motor is healthy and you dont beat on it. It will last a good while.
    you want a walbro 255 and 330 can be used, but your duty cycle will be unhealthy for those injectors.
    at stock fuel pressures:
    240cc=180whp ish (high 100's)
    310cc=210whp ish (low 200's)
    330cc=220whp ish (low 200's)
    450cc=275whp ish (high 200's)
    duty cycles will be pretty high especially if your fuel system/electrical is in anyway compromised. you can stretch smaller injectors by upping the fuel pressure, but when you figure the cost of buying an adj fpr and pressure gauge you could've done the right way by buying new injectors.
    200 tuned daily on a y8 is no problem depending on turbo.
    DC5-R
    Gwinett
    so instead of getting a fuel pump just get 450cc? And more than likely the turbo will be a T25/T28.
    you need a fuel pump too
    DC5-R
    Gwinett
    well here's what I have so far, and I'm planning on doing this right the first time around so I don't have to fix any mistakes. This will be my 3rd turbo project.
    I have all the pipings and fmic, drag manifold, wastegate, return line, missing link (don't want to use a fmu).
    And is a T25 able to obtain good power?
    MEGATRON 112480's Avatar
    Mobile,AL
    Well here was mine before it went Ka-boom:
    Garrett T3/T04e 57trim .63A/R
    Ramhorn Manifold
    Tial 38mm W.G w/ .1bar spring(14.75psi)
    750cc injectors(RC's)
    Walbro 255
    FMIC
    Skunk 2 I.M
    FULLY built head(with 1mm oversized valves)
    Si tranny with obx LSD etc etc
    Rods,Pistons etc etc
    Golden eagle Block Guard(A WASTE!!!! GET IT SLEEVED!!!, if going for a lot of power)
    3" exhaust etc etc
    Tuned by Scotty at Mainstream using Crome Pro
    300WHP&[email protected](.1bar spring)
    315WHP&249WTQ@18psi
    With a STOCK CAM!
    EBTEC
    EMMINO BUILT
    Allmotor K EK Hatch Coming Soon.....
    Don Mon SiRed94's Avatar
    Morrow 30260
    if you are going with the 450cc injectors, you will need to get the ecu chipped and when you do that they will make it where the map sensor can read boost and you wont need the missing link... the t25 is an alrite turbo that makes good midrange rpm power... but at high rpms it sucks ass... just make sure you get it tuned whichever route you decide...
    Quote Originally Posted by SiRed94
    agreed.
    to recap:
    fuel pump
    450cc
    fmic
    NO MISSING LINK
    chipped ecu/tuning
    t25 will be good low and midrange, but will fall off and not make as much peak power. t3 super 60 will spool a little later and make upper mid range and better peak power. those 2 turbo are reasonably priced. there are others that may be better if you want to spend the $$. if you go used t25, be careful. i've seen some used t25 that are pretty much worn out. after a rebuild you could've bought something better.
    DC5-R
    Gwinett
    I already have a hondata s200b so as far as ecu chipping goes that won't be needed. The reason I chose the missing link is because of my timing and schedule (I will need to make time to get it tuned).
    scotty - I thought that going with a smaller turbo would be better but I would rather make more power from mid-high range. So what recommendations would you have besides a super 60. Would a garrett t3 .50 trim be applicable?
    Pretty much any moderate T3 turbo will do.
    You can get a basemap for your ECU that you can drive on so you dont have ot have a missing link
    Morrow 30260
    T3's on d series will usually start making boost at around 4k, depending on the size/setup, but they will make power all the way to redline unlike the t25... which is good if its your DD because you can save gas when driving under 4k and still have enough rpm for boosting to mess around with (4000-7500)... so that's the turbo i would recommend...
    DC5-R
    Gwinett
    thanks for all the help ppl. reps
    Morrow 30260
    no problem gl man...
    Be Vivid magneto198's Avatar
    ATL/lenox/Lville
    anything is attainable with enough money
    Quote Originally Posted by IntegraXTR
    pm'd
    DC5-R
    Gwinett
    Ok, so I just got my snail and its internally wastegated. Here's the problem, my manifold is made for a external wastegate, which I have already (tial), so should I just go ahead and sell the turbo and get a T3?
    either sell it , or buy a block off plate for the external wastegate on te manifold
