Thread: RB25det idle problems and suggestions
    Skyline Powered!
    woodstock, GA
    Default RB25det idle problems and suggestions
    Car idles at first but after being reved up or put into gear and starting to drive when it returns to idle or trys to it will shut off and die totally. I tried pushin the gas pedal but it acted like the car was turned off, no response. But when restarted it idles fine. also when it idles it fumes fuel like crazy. My only guess so far is that it would need a fuel pressure reg. cause when it shuts off its like its flooding it. other than that aac valve does work and tried changing timing and it didnt affect it in any way. anyone else got any suggestions? besides gettin rid of it or anything stupid like that.
    drives a trycicle
    newnan
    It sounds like what my ka-t did to me. I never got around to figure it out. I put on a new IACV but it still did it. What are u tuning with? check your fuel map at idle, check for boost leak...are u running stock maf? what all do you have as upgrade?
    SPEED HAX nvmysrt's Avatar
    Beaufort, SC
    s1 or s2? how is it under load? have you checked your fuel pressure....check maf voltage?
    Beaufort, SC
    you there?
    2007-Magnetic Black 350z - JWT Popcharger, AAM test pipes*265whp/235wtq* SOLD
    Beaufort, SC
    check your static fuel pressure....check for leaks...i.e. intercooler piping, vaccums, anything vaccum related....makes sure you have good grounds.....make sure you timing is right....
    im thinkin rb's
    Beaufort SC
    nvmysrtcheck your static fuel pressure....check for leaks...i.e. intercooler piping, vaccums, anything vaccum related....makes sure you have good grounds.....make sure you timing is right....
    nvmysrts1 or s2? how is it under load? have you checked your fuel pressure....check maf voltage?
    HOMEMADE240SIt sounds like what my ka-t did to me. I never got around to figure it out. I put on a new IACV but it still did it. What are u tuning with? check your fuel map at idle, check for boost leak...are u running stock maf? what all do you have as upgrade?
    have you tried any or this yet???
