Results 1 to 3 of 3
Thread: Tuned R8's 2007 PPI R8 Razor &
    YoTa_BaNgEr YoTa_BoX's Avatar
    Dec 2003
    In a Yota
    Default Tuned R8's 2007 PPI R8 Razor &
    he PPI R8 and PPI R8 Razor – automobile lifestyle in carbon fibre
    With the launching of the R8, Audi heats up against rivals Porsche, Ferrari and Bentley vigorously providing stiff competition. The Swabian, German tuners PPI, customize Audi's flagship sportscar by stoking up the fire with even more coal going that extra mile by providing an enhanced look combined with improved driving dynamics. A wind tunnel-tested aerodynamic kit of carbon fibre in combination with a performance enhancement and special lightweight magnesium wheels in 19-inch dimensions provides measurably improved appearance whether on the race track or the elegant promenade of the elite jet set.
    Optimised performance for better resilience and increased driving pleasure
    The stage 1 kit produces an increase power output of the original motor from 309kw/420hp to 348kw/460hp and increases torque from 430Nm/317lb-ft to 465Nm/343lbs-ft. A performance kit with durable components designed by PPI consists of corrosion resistant stainless steel sport rear muffler with throttle system. Just beginning at low-end torque, the resulting sound signals pure power, but with high speeds one experiences an even more imposing sound. Matched to this is a complete optimised engine management plus sport air filter providing the unit with extra breathing abilities. Results are a top speed of 305 km/h and sprinting from 0-100 km/h in only 4,4 seconds; a two-tenths decrease versus standard production.
    PPI aerodynamics: continued further development in carbon fibre
    Without being overstated, PPI’s approach to the R8 was to retain the standard series design, with the addition of PPI developed aerodynamics. All PPI aerodynamics for the R8 are made of carbon fibre. This material is commonly used in motor sports reducing general weight yet simultaneously increasing sturdiness. This material is already featured in the Audi base model. PPI consequently takes a further step applying carbon fibre as the main component with highest quality for its entire car body material. Furthermore, PPI production carbon fibre parts are available in glossy or matte finish. The PPI aerodynamics package includes a lift reducing front lip spoiler. This more aggressive front air damn is designed to channel air to the front brakes, and cut through the air. In addition, the PPI designed, front bumper air intake “cartridges” were created for OEM fitting, and for improved air ventilation of the front radiator with separate air channel for brake cooling. Side sills sedate air inflow between the axles and provide this vehicle with a sporty and aggressive look even when standing still. It’s lateral appearance is completed with side blades in carbon fibre matte finish as standard production series offers carbon fibre glossy only. The diffuser with integrated PPI-designed air channels for exhaust pipe cooling stabilizes the rear with extra downforce and directional stability. The new double-sided rear grill deflects engine heat and exhaust system outwards and flanks the middle PPI rear plate. Rear spoiler with its adjustable wing increases downforce on the rear axle and completes the sporty elegant look.
    PPI MAG9: the lightweight wheel from PPI
    The new PPI MAG9 wheel design characterises the connection of high technical demands to sporty elegance. The two-part magnesium wheel with nine spokes and a wheel rim of carbon fibre commands not only by its exclusive look, but also through its outstanding craftsmanship setting new benchmark standards in the Audi tuning arena. The offered PPI MAG9 comes in dimension 9 x 19 front and 11 x 19 rear. Through the use of ultra light material magnesium resulting in reduction of unsprung mass, acceleration as well as deceleration and handling are distinctly improved. Weighing a mere 7,8 kg for front axle rims and 8,2 kg for rear axle rims, the PPI wheel are absolute champions in the lightweight arena. Optimal tires developed for the PPI R8 Razor in cooperation with Michelin are the supplied Michelin Pilot Sport Cup in dimensions 235/35 ZR19 (front) and 305/30 ZR19 (rear).
    Ideal interior engineering
    To complete the exclusive enhancements of the R8, PPI offers extensive modifications in materials and parts to the original interior. PPI offers handbrake, door entry threshold plates and middle instrument panel in carbon fibre. The technical highlight of the interior is the new PPI designed ergonomic steering wheel (available with Carbon Fibre sections) with additional interface controls for its driving dynamical program. Offered on special request is a personalized floor mat set furnished with leather trim. Also available is complete hand crafted precision leather, suede, alcantara upholstery from our in-house saddlers.
    engine Aluminum Alloy V8 e/Dry Sump Lubrication
    position Mid Lonitudinal
    aspiration Natural
    valvetrain DOHC, 4 Valves per Cyl w/VVT
    fuel feed FSI Direct Injection
    displacement 4163 cc / 254.0 cu in
    bore 84.5 mm / 3.33 in
    stroke 92.8 mm / 3.65 in
    power 343.0 kw / 460 bhp
    hp per litre 110.5 bhp per litre
    bhp/weight 294.87 bhp per tonne
    torque 465.05 nm / 343 ft lbs
    drive wheels Permanent Quattro 4WD w/Electronic Diffential Lock (EDL)
    body / frame Magnesium & Aluminum Body over Aluminum Spaceframe
    front brakes Ventilated Discs w/ABS, ASR
    f brake size 380 mm / 15.0 in
    rear brakes Ventilated Discs w/ABS, ASR
    r brake size 356 mm / 14.0 in
    front wheels F 48.3 x 22.9 cm / 19 x 9 in
    rear wheels R 48.3 x 27.9 cm / 19 x 11 in
    front tire size 235/35 ZR19 Michelin Pilot Sport Cup
    rear tire size 235/35 ZR19 Michelin Pilot Sport Cup
    steering Rack & Pinion w/Hydrualic Assist
    f suspension Double Wishbones w/Audi Magnetorheological Dampers
    r suspension Double Wishbones w/Audi Magnetorheological Dampers
    weight 1560 kg / 3439 lbs
    wheelbase 2650 mm / 104.3 in
    length 4430 mm / 174.4 in
    width 1900 mm / 74.8 in
    height 1250 mm / 49.2 in
    transmission 6-Speed Manual or 6-Speed R-Tronic
    top speed 305 kph / 189.5 mph
    0 - 60 mph 4.3 seconds
    Attached Thumbnails Attached Thumbnails -2007_ppi_r8razor1-jpg
    Life is a thought, think about it.
    Dec 2003
    In a Yota
    Design milestones of sports car construction do not only come from Sant' Agata Bolognese or Maranello but also from Kempten. Because there, in the picturesque Allgau region, Abt Sportsline, the greatest tuner for vehicles from the Volkswagen group, is based. With the new Abt R8, the term improvement is set one level higher as this car combines technical competence and brilliant design from Abt and results in an automobile masterwork. Not more and not less. The Abt R8 is a fantastic super sports car, playing in the same league as Lamborghini Gallardo or Ferrari F430.
    No doubt, even the basis model of the R8 is something special - and therefore a real challenge, emphasizes Hans-Jürgen Abt. ''The fluently dynamic form of the car is unique, it looks like having a lot of power, even when standing still,'' admits the managing director and therewith he raises the bar for his engineers and designers. As it is usual for Abt, the result is quite respectable and can be driven with fascination. The light and sporty high-tech material Carbon well visibly shapes the rear skirt, the side blades and the side skirts. The exciting body kit of the two-seater was developed by the motor sports professionals from Kempten who also optimized the car in reducing weight and in distributing mass evenly. That optical features do not obviate technical sophistications but, on the contrary, lead to perfection clearly show the contours of the Abt R8. Front skirt, side skirts, and rear skirt form a unit in which the rear wing, the side blades and also the exhaust system are harmonically integrated. A special highlight is the front skirt partially made of sight carbon. It is a component of the equipment version Extravagant. The customer is able to provide his Abt R8 with attachment parts, at his own option with elements of sight carbon. A two tone structure is also possible by request. Another alternative ist the equipment version Exclusive, which offers the customer the possibility to beautify his R8 with an Abt body kit made of high-quality GRP (glass fibre reinforced plastic). Also the new BR wheel from Abt with its bi-colour paint perfectly fits the car. The front axis presents it in the size 9x20 inch, the rear axis in 11x20 inch. Thus the R8 appears much more dynamical. With Abt suspension springs and car lowering the team from Kempten improves the road holding even more as Christian Abt and his specialists exactly adjusted the suspension. With the Abt sports brake system (380 millimeters diameter), the fast super sports car from the Allgäu sets standards also in matters of delay.
    The new Abt R8 is a car which makes hearts beat faster. It perfectly brings the magic of speed onto the road even when standing still.
    engine Aluminum V8 e/Dry Sump Lubrication
    aspiration Abt Supercharger
    fuel feed FSI Direct Fuel Injection
    power 395.2 kw / 530 bhp
    hp per litre 127.31 bhp per litre
    front brakes Discs w/ABS, ASR
    rear brakes Discs w/ABS, ASR
    0 - 60 mph 3.9 seconds
    Attached Thumbnails Attached Thumbnails -2007_abt_r81-jpg   -2007_abt_r82-jpg
    O jesus please no
    - IA Mgmt
