Results 1 to 16 of 16
Thread: 1996 GSR problem. HELP PLEASE!!
    FTP!! GSXR dude 95civictypeR's Avatar
    Henry
    Exclamation 1996 GSR problem. HELP PLEASE!!
    I have a ACURA INTEGRA GSR. about 2 weeks ago it started over heating and i replaced the themastat. It was doing good. then the radiator started smoking about 6 days later. I put a new one in the 27th of November, i dove it about 5 miles and it was still over heating and no heat. It went all the way to the H mark on the gauge within those 5 miles and it hasn't been on all day. then i went to hudson bridge and it wouldn't start.. then i thought it might be the spark plugs so i pulled them out.. there was oil on them.. NOT GOOD. then i bought some more and replaced them with new ones. It started right up. then i drove about 5-8 miles then it did it again. So i cleaned them of and tried it again.. NOTHING.. so i need some opinions on it.. THANKS..
    Guys: No Shirt, No Service
    Gals: No Shirt, No Charge
    Insanely Crazy
    Loganville GA
    When you replaced the thermostats did you also bleed air from the coolant system? Sounds like you have air in your system. I might want to also replace the radiator cap too. Oil in your spark plugs might also indicated your valve cover gasket is bad, so oil is leaking from the head into the spark plug tunnel.
    Henry
    im not sure.. i just replaced it.. and put it all back together.. but i thought it might be the head gasket.. so what should i do? put a new valve cover gasket on it.. and go from there?
    Go Dawgs
    SouthSide
    I live in southside too homie, shoot me a pm maybe i can look at it and help you out
    Tuned by Lil Ray Ray's
    aka Honda_Chick
    Winderrr Ga
    Quote Originally Posted by 95civictypeR
    Wow, that sounds exactly like what I'm going through. Cept, my car has 217k miles. That might have a lot to do with it. (When I find out wth is up with my car, I'll let you know. And visa versa) Good luck
    BUNG
    Jan 2003
    Newnan,Ga, USA
    have you done anything to check the head gasket? Try taking the radiotor cap off, and starting the car. If it errupts out of the radiator when you try to turn it over, i'd put my money on a blown headgasket...
    anyway it was oil and anti-freeze on the plugs?
    Single... but looking.
    Henry
    well not that i know of.. i only really saw the oil.. iam putting my money on the head gasket. valve seals..
    ya thanks alot honda chick.. ill let you know as soon as i get the head off.. which will be either tomorrow.. or thursday..
    ATL, GA
    i got a 92 integra my car was overheating 2.. it was leaking antifreeze from some of hoses.. is it leaking anti freeze?
    Eastside Boi!!
    Dec 2003
    Eastside, ATL
    sounds like u need a new head gasket
    Southside of The Jungle
    Quote Originally Posted by EclipseE16g
    I ll second that because my brother had bad gaskets for the spark plug holes and he had a hell of alot of oil in there.
    Henry
    ya i just took off the valve cover and its all milky so im jujst taking it all apart and rebuilding it.. thank you for everyones help..
    Henry
    ya its leaking antifreeze..
    chill six7teen's Avatar
    Columbus
    most defintiely a leak if it has the milky stuff on the valve cover. when i blew a head gasket, i was having these same problems and that same white goop. good thing is, head gaskets aren't to hard to change out on an integra!
    do it sideways SicK SilViA's Avatar
    mcdonough
    blow head gasket!
    94 honda integra
    90 240sx hatch(sold)
    92 240sx coupe(traded)
    93 e36 sedan (traded)
    89 240sx coupe
    BUNG
    Jan 2003
    Newnan,Ga, USA
    i only called that at like, the beginning of this month...
    If a radiator is "smoking" there's more issues then anyone but QD and his gang of ghostbusters can solve.
    ...Now if there is steam coming out it's a different issue that may be some what mortal. An aluminum engine on "H" is gonna be jacked, 99.9% guarantee you that at least the head and probably the block is warped.
    Remember head gaskets don't blow for ****s & giggles, especially on an N/A engine unless there is extreme pressure inside. the head gasket did not cause any of your problems, it was a result of prior issues...people always say "my head gasket blew and it did this and this and this because of it" ...nooo it blew because it overheated.
    I'll add more later!
