Thread: h23 non vtec head on f22 block
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    Default h23 non vtec head on f22 block
    is this possible? I'm looking to putting a jackson racing S/C on this set up as a second possibility in leiu of putting a turbo on the sohc.
    N/A>>><<<BOOST
    Kennesaw, GA
    the H23 is so cheap, why wouldnt you just get the whole motor. the head swap would cost just as much if not more, and would be more difficult to do
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Yeah its a 4 door
    my friend did the h23 head swap on his f22 in his CB7 and got it dynoed it only made 121 WHP same as a stock F22 would have nothing changed just maybe breathed a little better on top end and i dont think any companys support the H23 or F22 with any supercharger?
    At Home
    Swap motors Ill be easier or boost the F22 it would also still be easier.
    h23 head + f22 block = jdm f22b
    just boost the single cam or the h23
    About to approach beast mode
    Senior Member G.C's Avatar
    Forgot
    What turbo kit can you use on JDM F22b.???
    Yeah its a 4 door
    all turbo kits for either the F22A, H23, F22B, F20A are the same because all of their exhaust ports are the same, same with the intake manifolds as well or a 1st or 2nd gen DSM manifold fits on as well
    in your nightmares
    Quote Originally Posted by CB7tuner
    The HP is not the problem B/C I want to S/C it. I can still run bigger cams and keep my header if I go S/C and it would breath better on the top end.
    N/A>>><<<BOOST
    E-Thug SouthSide Tay's Avatar
    SouthSide Atlanta
    Go with the h23 and don't waste time ding a head swap im sure you could do the swap quicker than you could put the head and and torque everything down properly.
    - SouthSide Tay
    93 Sonoma
    -350ci SBC/th350/edelbrock single plane intake/holley 600cfm/dual flowmaster/3.73 rearend/ Weld prostars/ 27x8 Hoosier Slicks
    Daily Driven
