Results 1 to 14 of 14
Thread: Integra wont start??
    4WD>AWD KDM>JDM's Avatar
    Default Integra wont start??
    Alright, my friend has an 96 LS integra and a few weeks ago it got to where it didnt want to start, if you pumped the clutch and stomped it hard then it would start but with alot of grinding and loud knocking noise. Then it got to where no matter how much you pumped the clutch it wouldnt start so we replaced the clutch relay switch or whatever its called. Now it turns over but will not start up, we replaced the ignition coil and it still wont start. Any sugestions???
    check timing belt :]
    I dont think it would be out of timing, theres really no reason for it to be and the belt is not visibly messed up.
    I'd bet money that this is most likely your problem! These are the ones I use, and they work wonders!
    http://kalecoauto.com/index.php?main...products_id=13
    Banned CANCER's Avatar
    In your body
    Main relay
    Jonesboro/Stockbridge
    you got any check engine lights going on?
    did you check to see if you get spark or not?
    do you hear the fuel pump come on after two clicks of the key?
    check those and then come back.
    Quote Originally Posted by Init2winit
    lolol, I looked at that twice, thought about it for a second then said to myself you must be confused, Honda's don't have clutch belts...heyyy, wait a minute! lolol
    Quote Originally Posted by CANCER
    Main relay
    That or the rotor button.
    alright, the girl who owns the car knows nothing about cars so I'll have to check all those things tomorrow. I was just wanting some ideas because of the knocking/griding noise it made. Keep posting ideas though, everything is a possibility at this point cause we havent looked to far into it
    Quote Originally Posted by KDM>JDM
    ohh yeah, i forgot about the knocking grinding noise...yep back to the timing belt with that issue. Does it sound like it has compression when it turns over?
    I cant get ahold of anyone with the car right now so i cant really check these things till tomorrow. Cant the flywheel cause these problems too?? Or do they not even turn over with a bad flywheel???
    Coule be but highly unlikely...definitely wouldn't have any compression then.
    Certified Gearhead civicracer5000's Avatar
    atlanta
    have you check the distribuitor
    95 teggy for parts DaRussian's Avatar
    your timing belt could have jumped, i had bought a 95 integra not too long ago and when i started it, it sounded like the engine was blown or something... but i checked the timing and it had jumped couple spaces. after i redid the timing it runs like new
    SOUTHSIDE
    mine did that i thought it was the timing but with i checked it the timing was fine mine turned out to be that the screw the holds the rotor in the distribuitor fell off so it might be that....
