Thread: t3/t4 t04e turbo good for jdm f22b??
    Senior Member G.C's Avatar
    Forgot
    Default t3/t4 t04e turbo good for jdm f22b??
    T3/T4 T04E TURBOCHARGER. I am thinking of getting that turbo for my car. What do you guys think. Will that work for my car or will i need something smaller/bigger. reps will be given.
    JDM F22b:
    Specifications
    • Bore × Stroke: 85.0 × 95.0 mm
    • Displacement: 2156 cc
    • Valve Configuration: DOHC, 16 valves
    • Compression ratio: 9.3:1
    • Max power: 160 hp (119 kW) @ 6000 rpm
    • Max torque: 148 ft·lbf (200 N m) @ 5000 rpm
    Turbo:
    T3/T4 turbocharger with 2" Inducer and 3 " Exducer.
    .63 A/R Turbine and also has .50 A/R Compressor
    It comes with the standard T3/T4 Flange
    and yea its a ebay turbo but hey i dont have 2gz or 3gz for them good stuff you know.
    cant really say much but .. what turbo is right for you depends on what your trying to achieve
    Certified Gearhead spacelion's Avatar
    Metro Atlanta
    Proooobably shoulda looked around before you posted this,
    I'm sure you would've found the answer you're looking for.
    ][STREETLOVE][
    Quote Originally Posted by spacelion
    kinda like this thread
    ***The Big FAQ Thread- Honda/Acura, ECU codes, Swap Info, Wiring. READ FIRST***
    Metro Atlanta
    YEP! [/thread]
    ][STREETLOVE][
    wherever
    no, a t3/to4e will only work on USDM cars.... maybe some KDM ones too. But will instantly blow up on jdm engines.
    02' Miata
