Results 1 to 10 of 10
Thread: If someone wants to brace his frame....
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    Question If someone wants to brace his frame....
    In the rear of his car, to make the whole thing vibrate less, and become more stiff, etc., How would he go about doing it??
    He said he wants to try to find the upper part of his frame on both sides in the rear of his car, below the window and attempt to bolt a bar across it, almost the same way that a strut bar would install, only ON the frame, not in the strut towers. Would that work at all??
    \\\ATLANTA~ATNALTA///
    stockbridge
    supposing "he" didnt have a uni-body car.
    i dont really think there is a part of the "frame" that high up in a car that is strongly connected to the main "frame" enough to help.
    you confused me, so im pretty much gonna stop trying now though lol......
    OSJC driftyboy's Avatar
    Cartersville, GA
    Megan Racing makes a B-pillar and C-pillar bars for a few cars.
    http://meganracing.com/products/prod...e.asp?catid=72
    - Drifty
    Norcross
    Quote Originally Posted by driftyboy
    - Drifty
    Thats EXACTLY what im talkin about...!
    Repps if i could
    But, sadly, since the aftermarket for my car is lacking a little, ill have to make the brace myself....
    ....and Halfwit, just to clear things up for you a bit, the ''HE'', is actually me. I just didnt want to get flamed or called rice, because im starting to get into tuning and building my car a little more....
    Okazaki IronEagle's Avatar
    On the dyno
    You can always seam weld the body like raceteams do. Basically you go over the factory welds and make the chassis much stronger. A custom cage will also tighten it up nicely.
    Johns Creek
    Just put in a cage and be done.
    Flowery Branch
    im a welder
    Quote Originally Posted by madking411
    Just build your own using aluminum stock and some sort of turnbuckle...
    Drifter/Kneedragger
    Buford, GA, USA
    stiffening up the chassis will not cause the car to vibrate less...
    Quote Originally Posted by HiPSI
    exactly....vibrations are from solid or bad motor, drive line, and exhaust mounts. Then stiff suspension, bad bushings, lower profile tires, etc.
