Results 1 to 13 of 13
Thread: b18c1 questions
    Norcross
    Default b18c1 questions
    k, well im most likely getting a b18c1 swapped hatch soon, and im debating on turbo or all motor, so what all motor part/ parts would give me the most hp gain, i was thinkin upg. cams helpp! thanks
    p.s budget goin to b around 1,500$ thanks and reps
    I ♥ Sluts
    Henry Co.
    Boost
    Marietta, GA
    I love all motor vtec, my gsr is going to stay n/a. valve train and cams is a great hp gain, but watch out for overpowering everything else. just know that everything you beef up has the potential to break something else. i would recommend strengthening a few other things before you go straight for horsepower, like the oil pump, fuel and air regulation, motor mounts, etc. there's nothing like finally putting some cams in just to watch your valves break or your rods flying out the oil pan.
    for $1500 i would buy:
    HEader like i have for sale- 5 RAGE/HYTECH TRi-Y HEADERS!!! 30 DAY SPECIAL!! WONT LAST!!!
    Skunk2 Stage 1 cams- $350ish
    Skunk2 Intake manifold-$200
    Crome Pro ECU-$180
    Dyno Time -$320
    you should make around 175-180whp aka a 20whp gain over stock
    Norcross
    ^^ does this include them being installed
    no, thats just parts
    Temple of VTEC
    if you're going n/a then upgrade your cams they'll give you the most power upgrade. then again if you upgrade your cams then you need to upgrade your valvetrain as well...
    Temple of VTEC...
    02 WRX patrick4588's Avatar
    warner robins
    turbo
    GCO Member
    NRA Member
    chamblee
    aka Honda_Chick
    Winderrr Ga
    turbo.
    Certified Gearhead bernard's Avatar
    J-ville FL. FR. O'side Ca.
    Well, its all on you bro. If your motor is stock, you can boost it. But it won't last that long depending on how you drive. You can pretty much find all the good parts for that price around on sites for sale too. It all depends on how much you wanna spend for hp. Add your price for parts up, and look at parts for turbo. Don't go the cheap way either. Do it right the first time bro.
    Norcross
    ^^ yea still debating.. but i think imma get a skunk2 intake manifold. kuz it would b good for both turbo and all motor right?? and will this b easy for me to install and put on the throttle body on myself??!
    my momma's house
    Good call.
    Take your time. Trust me.
    If you want to go boost, and be reliable... $1,500 ain't gunna cut it.
    Get the Skunk2 intake manifold, header, cams, ecu and a tune, like Mike said.
    If having someone else do the labor for you isn't in your budget, try and get all the bolt ons first. Header, catback, intake manifold, aftermarket intake (Whale Penis FTMFW!), throttle body, msd, new plugs and wires, ect.
    Trend settin'
