Results 1 to 40 of 40
Thread: how to install header?
    i know all
    Default how to install header?
    it looks fairly simple, take bolts off at top, take bolts off at bottom, take the o2 sensor off, and then bolt everything back together again?
    is there anymore to it? do i need to buy any new parts or something?
    gasket(s) and what kind of car you working on??? that would help
    Scottish Scotsman's Avatar
    on the road to recovery
    torque specs are very important imo! other than that you said it all!
    Quote Originally Posted by tightflks
    repped for callin it a header!
    Dunwoody
    pretty straight forward if you have any doubt take it to a shop and let them do it
    i know all
    integra gsr, i need to buy new gasket(s)?
    and haha scotsman
    i would def change the gasket
    i know all
    is that something i can easily buy from autozone?
    do i need a gasket between the two pieces? i bought a two piece header
    Some guy. CSquared's Avatar
    You should theoretically need a gasket for any connection point in the exhaust... If not... You'll probably get a super fun exhaust leak.
    But yeah they should probably stock the regular gasket... If not... maybe a day to order.
    ^^^^x2
    i know all
    do 2 piece header come with gasket usually for the connection between them?
    i bought a ****ty one off of ebay =/
    i bought an egay one and it came with connection gasket , but i still had to but the exhaust mani gasket
    boost wanted GermanMuscle's Avatar
    Duluth, GA
    i just bought one from ebay aswell and it came with all of the gaskets but i plan on getting a new gasket for between the header and cylinder head. it is not in the best condition due to poor packing from the ebay seller
    90 Integra....Sold
    96 Jetta VR6...current money pit
    It should... but if it didn't... you can buy some "cut to fit" stuff at autozone.
    Mad Scientist xb1's Avatar
    Athens, Ga
    I don't know how well the "cut to fit" stuff will work on headers, since they get so hot. You really need something made of a compressible metal, like the flange gaskets. But you can try the regular stuff and see what happens.
    Athens, Ga
    Quote Originally Posted by TheScotsman
    this is very true. the torques need to all be equal to ensure that you dont get a leak down the road when the metal starts to change shape slightly.
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    if it comes with a gasket, just make sure its not a paper gasket... some manufacturers (especially cheaper ones) will come with paper gaskets just to say "gasket included". if thatsthe case, save yourself some trouble and but metallic gaskets.
    on a honda/acura 4cyl engine, header swaps are super easy. should take you less than an hour.
    boosted-eclipse
    yea put a good gasket on and please dont reuse the old one bc in time it will leak trust me
    i know all
    yeah it seems like i will just go ahead and buy a gasket from autozone
    yesterday we spent about an hour just jacking the car up hahahhaha, we had no jack stands so we went looking for cinder blocks, and having two blocks was not high enough and the jack wouldnt go high enough to put in a third, so we tried so many wierd setups to get it higher, the floor jack on top of a brick was just not working
    we ended up putting the spare tire jack on the brick cause it was more stable and that let us get that third block in, by that time it was gettin dark and cold so we said **** it and we will continue today, rep for all btw
    lol, $15-20 for jack stands just about anywhere...
    JDM TYTE AnthonyF's Avatar
    plus sequence. if you torque it in a random order you can warp the manifold or the gasket wont seal right.
    The Carbon Fibered R6
    Temple of VTEC
    omg
    Temple of VTEC...
    i know all
    really im jus going to tighten it as much as i can then take it to a shop so they can do it at the right torques
    still not in btw, by the time i got to the car, i didnt have the write wrench to unscrew the o2 bung and it got dark before i could find one and got test tomorrow
    i know all
    i dont even have 20 bucks to spend right now man hahaha
    and i wouldnt just go tightening up the bolts. at least do it in the correct order. and dont tighten em to all hell.
    just use cinder blocks
    your an idiot. you cant just tighten them down and then re-tq them later. The gasket will already be crushed so it wont seal right. to take a o2 out, 22mm wrench or they make o2 sockets you can buy.
    i know all
    i got the o2 out, had to place an order for a gasket, comes in tomorrow, so you're saying its gotta be done correctly the first time?
    yep , sequence is very important , any haynes or chiltons manuals will have it , good call 4.0!
    ^^ thanks man.
    yes, if you dont do it correct the 1st time (ask anyone who has built a motor) sometime is always bound to go wrong. if you tq it wrong, the gasket will get ruined and could create leaks will also warp the manifold.
    Senior Member BlkCD5's Avatar
    spray some wd-40 or some other lubricant so it'll ease up the bolts. You don't want to deal with a broken bolt.
    another good point , broken bolts suck!
    lol, you guys must take forever to get simple jobs accomplished.
    my b16 swap in my old EF took almost 4 months , it was due to lack of tools and funds though
    why? cus we like doing it correct the 1st time and not redoing it over and over again?
    and btw, I can swap my engine, trans, and s/c within a day. suck a nut.
    scotsman...^^i can only do that cus i have shop. correct tools help a **** load. but i feel ya.
    4.0 , wheres your shop and are ya goin to sonics tomorrow nite?
    scotsman-no, no meets for me. I dont go to meets until it's back to "normal" shop is on Buford hwy, south of N. Druid Hills. kayfunk just stopped by and i had to replace a headlight in his brothers car.
    besides, i have to watch the house. parents are out of town so i cant go anywhere really.
    10-4
    = 6
    I rarely ever have to repeat something because i did it wrong, lol. And i can also swap my engine and trans on nearly an vehicle within a day pretty easily also. But like you, ive got a shop and tools.
