Results 1 to 22 of 22
Thread: Halo 3 skulls, list and ?
    Default Halo 3 skulls, list and ?
    Supposedly these are the list of skulls and locations....
    can anyone verify these??? and i found the "blind skull" the other day and it didn't give me credit for it.. so i'm a bit confused... maybe i just need to start over...
    someone let me know what's up...
    "GOLD SKULLS"
    Iron Skull
    If you die, you restart from the beginning of the level.
    Iron Skull Location
    The “Iron Skull” is located at the very end of the first level, “Sierra 117″.
    It is located behind the building where Sgt. Johnson is being held captive, up on the roof.
    You can gain access to the roof on the far right side of the building.
    Travel all the way over to the left side of the roof, and the Skull will be concealed in the corner.
    Black Eye Skull Effect: When you lose shield, the only way to get it back it to melee an enemy.
    Black Eye Skull Location:
    This Skull is located in the beginning of the second level “Crow’s Nest”, the very room you start in.
    Hanging down from the ceiling is some piping. On top of this piping, on the side nearest to the large display (the one that Hood appears on)
    lies the “Black Eye Skull”. You can gain access to the pipes a few different ways.
    Tough Luck Skull Effect: Your enemies never back down, always make their saving throws, and always charge you.
    Tough Luck Skull Location:
    The “Tough Luck Skull” is found on the third level, at the point in the level when the huge covenant cruiser flies overhead.
    On your left is some large piping following the road you are walking on.
    Underneath this piping are some support beams that extend out over a cliff.
    Jump onto the first of these beams, and travel to the end of it. Look to your left,
    and the Tough Luck Skull will be sitting on a rock extending from a cliff edge.
    Catch Skull Effect: Your Enemies throw LOTS of grenades.
    Catch Skull Location:
    The “Catch Skull” can be found on the fourth level, in the first area where you need to destroy the Wraith Tanks.
    When you enter this area, do not eliminate the Wraith Tanks
    (The skull appears when the tanks appear, and disappears when the tanks are destroyed).
    The Skull is located on top of the circular building next to the Anti-Air Tank.
    You can access the roof using a grenade jump, or jumping on the back of a hog.
    Fog Skull Effect: “You’ll miss those eyes in the back of your head.” You lose your motion sensor.
    Fog Skull Location:
    The Fog Skull is found on the level “Floodgate“, at the very beginning of the level.
    As you are walking down from the anti-air gun you destroyed in the previous mission, you encounter a ramp (next to a missile launcher).
    Around this ramp, you hit a checkpoint. At this point, you should also hear a marine yelling, “There! Over There!”.
    You have a small window of opportunity at this point, but it is fairly easy to get the Fog Skull.
    Look up, and to the right, directly at the roof of the building next to the missle launcher.
    There is a single flood form (not to be mistaken with the two other flood forms jumping in front of you) which is holding the skull.
    Kill him before he jumps, and he will drop the skull down to the ground where you can retrieve it.
    Too early, and the skull will get stuck on the roof though, so just time it carefully.
    Famine Skull Effect: Enemies drop 50% of the ammo they usually drop.
    Famine Skull Location:
    This skull requires a bit of grenade jumping skill/luck.
    You can find the “Famine Skull” on the sixth level, near the point where the path you follow branches off into two sections
    (one leading to the area where you need to let the tanks across the bridge, and the other leading towards the area where you meet up with the frigate).
    Take the right path, as you would if you were completing the mission, and you’ll notice a structure above you / to the left of you (near the area where you encounter a few ghosts).
    You need to scale the rocks to the right of the structure, and then travel across it so that you pass 3 of the large support beams extending into the cliffs.
    Inside of the fourth support beam, lies the Famine Skull. A well placed grenade should have you up there in no time!
    Another Way of getting the skull according to Kaboodle is to Hijack a Brute Chopper
    (there are plenty in the level that you can take), and then drive it up the rocks to the right of the structure,
    and jump the ledge onto the structure. Once on top, simply park the Chopper on the slant leading to the skull, and jump on top of the chopper,
    and then jump to the skull.
    Thunderstorm Skull Effect: All enemies are given a field promotion, and ranked up to their next available level.
    Thunderstorm Skull Location:
    The “Thunderstorm Skull” can be found on the level, “The Covenant”, after you take command of one of the Hornet vehicles.
    Fly towards the second force field generator (the one the Arbiter disabled), and land.
    The skull is waiting at the very top, at the end of the ramp extending over the sea.
    Tilt Skull Effect: Makes enemy resistance much greater. For example, Brute power armor becomes nearly impossible to take out with nearly anything except for plasma bursts.
    Tilt Skull Location:
    The “Tilt Skull” is found on the level “Cortana”, in the circular room where Cortana mentions that she “Likes to play games too…”.
    It’s a bit difficult to get to, as it requires getting on top of the ceiling of the room.
    Upon entering the room, head towards the left side where you will see some mushroom shaped extrusions along the wall.
    Get on top of these, and then look up and towards the right for another set of extrusions. Jump to these.
    From here, you should be able to jump on top of the ceiling of the room, where the Tilt Skull lies in the center
    Mythic Skull
    Mythic Skull Effect: All enemies have double their usual health.
    Mythic Skull Location:
    This is probably the easiest Golden skull in the game to get. It is located in the very beginning of the final level in Halo 3.
    Begin by heading into the canyon, but hug the right wall. Very soon, you will notice that there is a turn to the right that is off the normal trail.
    Head a bit down this path, and the “Mythic Skull” will be sitting there.
    "SILVER SKULLS"
    Blind Skull Effect: You lose your HUD when this skull is turned on. You won’t see your weapons, shield, radar, etc.
    Blind Skull Location:
    The “Blind Skull” is the first of the Silver Skulls in Halo 3, and can be found in the first mission, “Sierra 117″.
    It is located relatively close to the beginning of the mission.
    After your first encounter with the Gold Armor Brute, Two enemy dropships will appear a bit further down the stream.
    Go towards the dropship that is furthest away, and stay on the right side of the stream. Continue along the right (towards the cliff edge),
    and a rock will jut out a bit over the large lake. The Blind Skull is located on this rock.
    Grunt Birthday Party Skull Effect: When you get a headshot on an enemy Grunt, they will explode into confetti, and you’ll hear children cheer, “Yay!” in excitement.
    Grunt Birthday Party Skull Location:
    This is one of the more fun Silver Skulls in Halo 3.
    The “Grunt Birthday Party Skull” is located on the second mission, “Crow’s Nest”, just before the area where you team up with the Arbiter
    (it’s the piping area where you see Drones buzzing in and out of an array of pipes).
    Just before you jump down the pipe to meet up with the Arbiter, stop at the ledge, and look directly below you.
    Along the wall that you drop down, there is a small ledge with a green arrow pointing backwards.
    jump onto this ledge (rather than all the way down), and go inside this secret room.
    The skull is in the dead center of the room.
    Cowbell Skull Location
    Cowbell Skull Effect: Explosions become much bigger in the game.
    Cowbell Skull Location:
    The “Cowbell Skull” is found on the level “The Ark”, and marks the third Silver Skull found in the game.
    It’s fairly far into the level, so it takes a bit of time to find it.
    Begin by heading all the way to the part of the level where you battle the Scarab.
    After defeating it, look in the middle of the desert area which you battled it in for a fairly large structure
    (it’s the building you see if you are at the bottom of the ramp you are supposed to go up, and turn to look in the opposite direction).
    Inside of this structure are several Gravity Lifts (shown below). Take one of these for later.
    Next, head up the huge ramp, and head inside of the building (the one with the cartographer inside).
    Pass through a few of the rooms in this building, and you’ll eventually come to a room with a whole lot of Explosive crates.
    Right after this room is a Staircase/Hallway that leads to the level below.
    The Skull is located at the top of the room, at the point where you turn on the staircase to head for the next part of the slope.
    There are four platforms above you, the Skull is on the uppermost of these platforms.
    Use the Gravity Lift to jump up to it, and there you have it!
    IWHBYD SKULL
    After jumping through them in this sequence, you will be awarded the “I Would Have Been Your Daddy Skull”.
    It will be right next to the bridge that brings you over to the Prophet of Truth.
    NOTE: YOU MAY NEED TO KILL THE PROPHET OF TRUTH, AND THE FLOOD BEFORE DOING THE RING JUMPS!
    Special Notes:
    The Skull is located in the level, “The Covenant”.
    After defeating the Scarabs, and going inside, get to the location with all 7 Ring Holograms.
    You must jump through the rings in a specific order. That order is as follows (1 is at the entrance, 7 is at the end)4 6 5 4 5 3 4)
    When you jump through the final halo, the rings will start lighting up in a linear fasion.
    Go grab the Skull over at the Bridge that connects to the Control Panel.
    When you grab the skull, all of the rings will start playing the main Halo Theme Song.
    You can work as a team in co-op with 2-4 players jumping through the rings to speed up the process.
    Just make sure that the rings are jumped through in the correct order as a team. It really speeds things up this way.
    If you mess up, you can start the sequence over without restarting the mission.
    Some people believe that you may need to finish the level to get the skull. It’s worked both ways according to reports.
    No
    *clears throat*
    GameFAQS has had this for how long, Killer?
    this is the first time i looked into it.. that's why i'm asking if these are right...
    Senior Member antiv6's Avatar
    g-nett
    so who wants to get me the IWHBYD SKULL ive tried twice with no success. that the only one i need really
    um.... u scratch my back i'll scratch yours???
    in a non sexual way of course.. lol...
    g-nett
    i dont get it how bout you just help me get the skull lmao
    Quote Originally Posted by antiv6
    i mean help me get the rest of them.. and i'll help you get that one...
    g-nett
    ya i can help with some i still need to beat a few levels on legendary also just let me know when u wanna do it(in a non sexual way lol)
    my username is Aniv6 on xblive
    Cummin In
    well... add me if you need help with one of them, i don't mind playin halo for one skull...... but not all of em.... GT is Stickiestfire
    g-nett
    Quote Originally Posted by Sticky
    i sent u a friends request let me know when u wanna help me get it
    you guys blow...
    g-nett
    you guys blow...
    ya well you blow guys
    ill still help you get skulls whenever i have enough time to play the game maybe even tomorrow just add me
    NO SIR I DO NOT!!!
    i just want to know if this list is legit?
    if you have to be online for them to count?
    GT is THXS KATRINA
    Gainesville
    youtube pwns joo
    JUST ANSWER THE QUESTIONS BITCHES!
    Gainesville
    YOUTUBE AND GOOGLE IS YOUR FRIEND
    Henry Co.
    if you get all the skulls you get the hayabusa armor.
    and if you get all the skulls and all the achievements you get a samuari sword.
    look up my gamertag on bungie, youll see : Oh My Godfather
    K-Town!
    Lol @ this thread.
    Henry Co.
    Lol @ you, for Lol'ing @ this thread.
    Gainesville
    lol at dumb ****s?
    Quote Originally Posted by §treet_§peed
    WHERE DO YOU THINK I GOT THIS LIST DUMMY!!!??!?!!!
    oh and again, i started over completely last night.. got the "BLIND SKULL" and nothing happened at all... do you have to be online for this to work properly and it store your achievements???
    g-nett
    somke skulls dont give you achievments
