Thread: Falken Tires
    The Valley
    Default Falken Tires
    Are the Falken RT-615 Drag Radials??? If not, does Falken make any???
    decatur
    no though they work rather well, and no to my knowledge falkin does not produce a drag radial.
    The Valley
    Quote Originally Posted by wantboost
    o i see,
    Will the Falken RT-615 catch better traction than the Bf Goodrich g-Force DR's with both being 205/50/R15???
    It seems like it would.
    decatur
    i would go with the dr's if you are going to be dragging and 615 for auto x/ track days
    The Valley
    alright BF Goodrich DR's it is then.
    Senior Member EJdm's Avatar
    falken use to make the rt-215...they were some what drag radials i believe...very sticky when hot...
    ATL, GA
    615 is the best non- R compound tire you can get.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Quote Originally Posted by EJdm
    rt 615 are just the newer version of the rt 215
    70hp FTL StraightSix's Avatar
    Central, SC
    Quote Originally Posted by chituntang
    I would respectfully disagre with that. The RT-615s were the best non-r comps that one could buy, and used to THE tire to have ST autocross classes. Now, I think the hot tire is the new Bridgestone RE01.
    Kumho and Toyo are both slated to release new tires to compete with the Bridgestone for ST class supremecy.
    Oh, and to answer the OP's question, no, the RT-615 is not a drag radial. Nor does Falken make a drag radial.
