Results 1 to 22 of 22
Thread: camber wear
    jack daniels addict integra938's Avatar
    marietta
    Default camber wear
    camber wear how fast is going to screw my tires ? im about to drop my teg with some tein sping 1.7 and front back.. i guess what im trying to say it how fast will my tires go ?
    Shine on! Nittanys1's Avatar
    Raleigh, NC
    depends on a lot of factors. the type of tire you run, its tread wear, the amount of camber you'll have, they way you drive, tire inflation....etc... Just do it right and get a camber kit and put it on when you get your suspension installed.
    marietta
    whats a good offbrad of camber kit ..?
    marietta
    would something like this work fine ?
    http://cgi.ebay.com/ebaymotors/94-97...spagenameZWDVW
    Don't buy off brand suspension products, get the real thing like blox, skunk 2, omni power and ingalls.
    clayton county
    ^^ yups... those brands are cool.... but 1.7 inch isnt much to kill your tires. i have some cooooopers tucking tires and scrubbing for 4 months, maybe.. they looook brand new. it's still even. lol
    I give out reps....
    clayton county
    I give out reps....
    Yeah man. Fr33way's Avatar
    North OTP
    With good alignment I do not see 1.7 as being a problem. Toe is much more damaging to tires.
    Raleigh, NC
    naw he should get a camber kit while at it.....the camber will make him run through tires. y not stop it before it starts...
    itakepictures
    changaroopouch
    screw the camber it, its worthless.
    what most people dont know is that its the toe that eats away tires, not camber.
    take your car to a good alignment shop and get the toe zeroed out. dont buy into the whole camber kit bs.
    Roswell, GA / Georgia Tech
    well i know from experience that my car ate through tires, until i got a camber kit installed
    i'd definitely do it, i wish i had done it from the beginning.
    BYT joesblk_teg's Avatar
    kennesaw/L-ville
    get the nitto neogins my car is slammed and you cant even notice any ware on my tires that have been on for about 7k miles
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    comber doenst wear ****
    TOe does
    i have -5* of camber on my front wheels....and i dont have any unusual wear after 4 months
    North OTP
    I have been anywhere from stock height to slammed with -3 camber, same wear with proper alignment. Only my experience.
    saudi arabia
    yeah, i have more camber in my front wheels, than my rear wheels.
    and more than most people have in their rear wheels
    camber is your friend.
    North OTP
    ^^^ Word, A32 multi-link ream beam != camber adjustable FTL.
    saudi arabia
    you can
    me and a guy actually cut, angled and reweled the rear shafts to make his A32 camber....
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Toe is the main problem with tire wear. Some negative camber is actually good for handling because when you turn more tread of the tire touches the ground
    I must agree camber is good.
    marietta
    anyone know that site that you can see how rims look on your car and also lower it ?.. i had it befor but i cant remember it
    Don Mon SiRed94's Avatar
    Morrow 30260
    yeah 1.7 really isn't gunna affect camber much... however negative camber can cause extra wear because the weight of the car is resting on a smaller portion of the tire causing more stress on that area, rather than distributing the weight evenly across the entire surface area of the tire.... but personally, i love about -4 degrees of camber and don't give a damn if my tires suffer
    Morrow 30260
    Quote Originally Posted by integra938
    i believe its tirerack.com or something like that....
