Results 1 to 29 of 29
Thread: Our pet hamster has escaped...
    HIV+ HalfBaked's Avatar
    Default Our pet hamster has escaped...
    Our hamster last night escaped from her cage...
    Looked for her today and couldn't find her. Now it isn't like I care about it because it is well just a hamster, but I don't wanna just be laying there and have some critter crawl into my butt...
    How do I bait it out of hiding without using a mouse trap...
    the land of race car ya-yas.
    Quote Originally Posted by KDM guy
    You'd be worried too about rodents burrowing into your buttocks while you were sleeping if you didn't enjoy it too much...
    ....ok actually I made this thread because the gerbil creature escaped from my butt during our sexcapades last night.
    K-Town!
    WTf.....Lstone said that quote in your sig??
    Yes.
    It was in reference because his dog ate one of my used condoms.
    K-Town!
    Wow. *sigh*
    IA IS FOR FAGS coolcat's Avatar
    FAGGOTS
    When I was younger I lost my hamster and found it one mornin zooming around our kitchen. Just be patient, you'll eventually see it running around, or buy a small animal trap (not the ones that kill them) put some corn in it and BAM, hamster pwnzihilation.
    BUY MY NEW BOOK! ITS CALLED, IF YOU LIKE IMPORTANTLANTA THERE'S A STRONG CHANCE YOU'RE A FAGGOT
    ya you can buy hamrless mouse traps
    Well, we have 2 dogs.
    A pit and a boston terrier.
    Both have always wanted to eat the hamster.
    Most likely they'll find it before me.
    I just hope I can film the brawl.
    Your Moms Moderattor
    pleasant hill
    wait till his starts tearing up the inside of your house, chewing up everything in his path.
    Quote Originally Posted by coolcat
    I highly doubt any of that was true. You had a hamster, but you didn't lose it you stashed it somewhere where it later rotted and left it's smell for life.
    Yeah you will find it btw
    Lurker Brick's Avatar
    Canton, GA
    "Tips on Finding and Catching a Hamster on the Loose
    Hamsters are surprisingly good escape artists and sometimes get away when they are out to play. They can fit into tiny spaces and can disappear quickly, and getting them back can be tricky. If you are lucky, just leaving their cage open might be enough to entice a lost hamster back home. In the meantime, here are some tips to help you find a lost hamster:
    Where to Look
    The first thing to do is to look in some common hiding places. Do a thorough search as soon as possible after you lose your hamster, remembering your lost hamster is probably scared and will look for a secure hiding spot:
    * Start your search near the cage and go from there.
    * Check behind and under furniture, as well as down the sides and backs of sofas, under cushions, etc.
    * Check cabinets, drawers, shelves and bookcases. Don't forget to look inside, behind, and under items kept in these places.
    * Check the underside of furniture and beds for any holes through which a hamster could climb inside the furniture/bed.
    * Check inside any boxes you have around the house, including tissue boxes.
    * Look inside any backpacks, purses, other bags, and shoes.
    * Check the undersides and backs of appliances for holes into which your lost hamster could have climbed.
    * Look for holes or spaces under cupboards or that could lead into the walls. Make a note of these for later.
    Tracking a Lost Hamster
    Unfortunately, it may be next to impossible to find a lost hamster. You may not even know which room your hamster is hiding in. Here are some tips on tracking hamsters:
    * Remember that hamsters are nocturnal, so will probably only move about overnight.
    * Place a small pre-counted pile of sunflower seeds on the floor in each room. If any seeds disappear from a room, that gives you a better general idea where your lost hamster is hiding (unless you have any wild mice that are stealing your bait!).
    * Sprinkle a little flour or cornstarch on the floor around the piles of seeds. A trail of little white footprints may lead to a hamster's hiding place.
    * Similarly, sprinkle some flour across doorways and in front of any suspected hiding spots (like spaces under the cupboards or holes in the wall, as noted on your search). Check for footprints to see where your hamster is travelling at night.
    * In the evening, try placing tinfoil or crinkly cellophane on the floor (concentrate on possible hideouts, doorways, and around the cage or food), turn out all the lights and sit quietly. If your lost hamster comes out, you may be able to locate it by the noise made as it walks across the foil or cellophane.
    Catching Your Hamster
    Sometimes, hamsters are not that easy to catch, even if you locate them, so you might have to set a "trap" to catch your lost hamster:
    * Some hamsters will come back to the cage on their own. Leave the cage open on the floor (with a supply of fresh food), near its usual location (or closer to where the hamster is hiding if you suspect a distant hiding spot). You may have to stay up late to close the door on your hamster when he or she returns, though often they are happy to be home and settle in for a nap after eating.
    * Set up a "bucket trap" by getting a bucket (deep enough that a hamster couldn't get out of but not so deep that a hamster would get hurt falling in), and place a thick towel on the bottom. On top of the towel you place some really tasty treats such as a thin layer of peanut butter on a cracker, apple slices, and/or cheese (something the hamster will easily smell). Then, make some sort of ramp up the outside of the bucket using wood, a wire shelf, or books stacked to make a staircase. The idea is that the hamster will go up the ramp in search of the food and jump into the bucket to get it, but can't climb back out. I have never tried this personally but have heard it works; the trick is to make the treat so irresistible the hamster will be willing to jump in the bucket for it.
    * As a last resort, get a humane mouse trap, also called a live mouse trap (the kind that is a box that traps the mouse without killing it) and bait it with peanut butter. These do occasionally malfunction so could possibly injure your hamster, but that is fairly unlikely and they usually work well.
    Remember to be patient and do not give up too quickly. Hamsters seem to manage on their own quite well for a few days, and I have heard from several owners who were sure their hamsters were gone for good then were surprised to have them turn up suddenly after a couple of days. "
    in the dark...
    yell out loud that JJALFANO is coming by to dry some clothes...
    :) LiL PaKi's Avatar
    in my own lil world
    leave some hamster food on the floor and wait...
    MAY CAUSE CANCER Psycho's Avatar
    Standing Right Behind You
    dangle a piece of cheese on a string with your butt cheeks.
    Curiously Cynical DrivenMind's Avatar
    You could always give Richard Greer a call, I hear he's good at solving these kind of problems...
    FAGGOTS
    You caught me, I have to start somewhere on my future career as a serial killer, DUH SIMON, THINK THINGS THROUGH SOMETIMES, HONESTLY.
    FAGGOTS
    You can wait for it to come out, get someone's coat, throw it over it and then bash it with a hammer.
    +1 to anyone that knows the reference to this epicly awesome movie.
    IA.COM Founder.
    Nov 2000
    you have to dogs? hnmm.. It may be to late already.
    FAGGOTS
    Lol, I remember my friends dog being absolutely terrified of his gerbil. I'd be really worried if you had a cat.
    When did y'all get a hamster...and why?
    Val for president!
    Facebook.com/TracyATL
    FAGGOTS
    Quote Originally Posted by Tracy
    Because they are cute, duh.
    Well I know. I have 2 gerbils and 2 chinchillas. Halfbaked once put my cat in my gerbil cage and then in my chinny cage. Thats why I ask.
    Val for president!
    Jay G. 1439/2000's Avatar
    Location, Location...
    Quote Originally Posted by DrivenMind
    Gere.
    And nobody on here remembers that except me. Until now, where someone will have Googled Richard Gere + Hamsters and found out what he did. Then they will post as if they knew what you were typing about when you said it but they didn't.
    I had a pet hamster when I was 5. His name was Waffles and I killed him. It was an accident but I didnt know he was that bad at air hockey.
    Quote Originally Posted by 1439/2000
    Gere.
    Um, I remembered that, too. Don't you remember my "so many gerbils, so little time" bumper sticker on my gerbil cage? Yea...and the toilet paper roll taped up by it? That was my Richard Gere reference.
    Val for president!
    Drag your feet when you walk in your house.
    FAGGOTS
    [EMO][/EMO]
    [EMO][/EMO]
    What, I don't want him stepping on the creature!
    FAGGOTS
    Haha, then it would be [LIFE][/LIFE]
