Results 1 to 16 of 16
Thread: I NEED help with my ls/vtec conversion!!!
    GetItFixItFlipIt Timinater's Avatar
    Default I NEED help with my ls/vtec conversion!!!
    I just recently bought a 92 eg with a gsr swap, and this past saturday threw a rod and destroyed my block. well fortunatley i have an ls motor that isnt being used. my goal is to build a 200 whp ls/vtec as soon as possible. I have been doing a lot of research, the most helpful thread i found was http://b20vtec.com/forums/b-series-t...tec-guide.html
    i need all of these items, but im not sure of the best place to get them
    LS ARP rod bolts
    GSR ARP head studs
    New OEM LS (90-01) B18a/b head gasket
    New OEM/ACL LS bearings
    Shotpeen LS rods
    New hastings/OEM p30 piston rings
    New OEM valve seals
    p30 piston
    cams
    camgears
    valve springs
    any help is greatly appreciated
    Senior Member BlkCD5's Avatar
    contact mainstream performance for some info. Also check out the sticky on all motor builds.
    thanks
    Hwy 315
    www.kteller.com
    www.robearracing.com
    www.honda-tech.com
    www.streetrays.com
    I'm glad to see you're getting your car back together bro. That sucks what happened
    ...you still had the "i can't believe that just happened" look on your face when i pulled up. ...it happens to the best of us bro
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Cummin In
    im in the process of building one right now, give mainstream a holla and they will take care of you no doubt
    LS ARP rod bolts-NOPI.COM
    GSR ARP head studs NOPI.COM
    New OEM LS (90-01) B18a/b head gasket-
    New OEM/ACL LS bearings- GET ACL from Kteller.com
    Shotpeen LS rods- Dont do it, waste of time
    New hastings/OEM p30 piston rings- HONDA
    New OEM valve seals- HONDA
    p30 piston- Get PR3s from Toplineauto.com
    cams- I reccomend PRO1s
    camgears- Skunk2
    valve springs= Skunk2
    I hold the record for the highest B series in GA, 237whp LSVTEC.
    I work for Batlground, if you want i can order parts an have pretty good connections with people to get what you need.
    Hwy 315
    ^ Mike is living back in the glory days
    -jonathan
    [/URL]
    No glory really, just letting him know i have alot of expierience with LSVTECs so if he needs help, PM me.
    and i know where to buy parts from
    baodalazi @ COD4
    bayou la batre
    gl on the build
    Temple of VTEC
    that sucks man..but the ls/vtec should be pretty stout
    Temple of VTEC...
    TheMyth
    It does suck when your motor goes. It doesnt matter if its built or stock. It was your transportation that just let you down. Good luck with the build. It ought to be pretty good.
    hey, i really appreciate everone's feedback, thanks ya'll
    Macon
    Quote Originally Posted by Timinater
    LS ARP rod bolts
    GSR ARP head studs
    Shotpeen LS rods
    New OEM valve seals
    p30 piston
    cams
    camgears
    valve springs
    sounds pretty good, except I would go with aftermarket rods (eagle esp are pretty good for N/A builds). If you want to make good power, you will need to rev higher. VTEC engines make the most power at high RPM's, and LS rods just cant safely and reliably handle frequent 8K+ rpm pulls. $350 will get you a set of eagle ESP's with ARP bolts. Nopi has them for $342 plus tax/shipping, but they have a lot of coupons this time of year, so you may be able to get them for close to $300.
    Land Rover LR3 HSE
    come get some superman's Avatar
    Dream Land
    Summit has the rods cheaper than NOPI check them out and compare price for the rods for your Ls. On b20vtec they have a skunk2 vender that has a lot of new skunk2 parts on sale for the holiday season.
    Your mom's bed
    + for a fellow LS/VTEC builder
    Alpharetta/Duluth
    sounds like you are going to have fun with your ls/vtec build.
    Just a note, go with SCAT rods they seem to be machined a little more precise than some of the eagles that my engine builder has seen.... safe bet if you are going to do the build yourself. Scats are no more $$ than eagles, and they are basically the same rod.
