- HOSE CLAMPS???
HOSE CLAMPS???
what are the best kinda hose clamps??
like coolant hoses...
there are like 3 damn kind on my monter.. i replaced the hoses and there is still a damn leak.. i know it's cause of the clamps....
there is the "spring/pliers" type... the kind that cross over each other and you pinch with pliers to open....
the kind that has a screw in it that you just tighten and it uses the thread on the metal band to tighten..
and another type that is a combination of both... the clamp itself crosses over itself.. but also a screw that actually pushes the clamp closed (not like the type i described before)
either way... these two particular hoses are the hardest things i've ever tried to get to on a car... they are on the back of the engine... and there is practically no space to get to them... with anything...
any suggestions.. or someone just want to be awesome enough to come fix it for me? i'm tired of the simplest of jobs turning into ridiculously retarded tasks....
- HOSE CLAMPS???
- You may not post replies
- You may not edit your posts
Forum Rules
