Results 1 to 16 of 16
Thread: Those of you who went to ImportFace Off
    140 on one wheel
    columbus, ga
    Default Those of you who went to ImportFace Off
    How'd you do at the track? And did you like it? It sucked for me. I was shooting for mid 12's but the best i got was 12.9 at 116mph with a ****ty 2.4 60ft. (18's and street tires FTL!) My other runs was two 13.3's and a 13.4. Overall it was a pretty good event but it took to long to get in and to run. I think i waited a hour and a half to get in. And then there was times i waited an hour or a little more to run.
    ATL, GA
    Need to lose those 18s. But those are not bad times.
    jk
    Privateer Racing!!
    Duluth,Ga
    11.2 at 139mph on 19psi!!
    Oh and I won 2nd place in FWD class!!!
    140 on one wheel
    columbus, ga
    Quote Originally Posted by chituntang
    yeah i wanna drop down to 17's for DD but i was a set of stock se rims for the strip with some slicks or drag radials.
    Duluth, GA
    +1, 18s are more likely for show or for DD if you prefer. get some 16 or 17 and put some drag tire on. Look to see your new times.
    140 on one wheel
    columbus, ga
    Quote Originally Posted by cdhtang
    yep...im still on an open differential too Once i got a daily driver im gonna weld it.
    Smyrna
    Quote Originally Posted by SpoolNSlide
    Pretty good times.
    Off Topic: Ur sig says ur running 20psi, did u change out the stock head gasket? I heard it was only good to about 15-18 psi. Just curious Im building an SR myself, Ill understand if you don't wana share ur setup.
    He has an sr with cams and shit
    140 on one wheel
    columbus, ga
    Quote Originally Posted by TS240
    Pretty good times.
    nope whole motor is stock..just a couple of bolt ons. I only run 20lbs if i run for money or run somthing i think will get me...i was running about 11-14lbs at the track depending on what gear i was in. I think my turbo is about to take a dump on me so im about to upgrade to an Forced Performance 20g. Also im running a stock o2 housing and crush bent 3 inch down pipe and exhaust so it's robbing me of horsepower. I talked to guy with a simalar setup but his was tuned and he had lsd, drag radials, and a better exhaust setup and he was only running 13.4's and 13.5's. On 18lbs.
    Smyrna
    nope whole motor is stock..just a couple of bolt ons. I only run 20lbs if i run for money...i was running about 11-14lbs at the track depending on what gear i was in.
    Thanks, Im getting an 89 next week with a rebuilt redtop with blacktop pistons, so I was curious just how hard I can push it when its broke in. Its my 3rd 240 but my first sr so Im kinda a noob.
    140 on one wheel
    columbus, ga
    ive got a stock red top and so far so good. My compression was 175 across the board and i have yet to see another motor with as high or perfect compression number. Most say there's are low 160's or lower.
    Smyrna
    I'll have to do a compression test next week, its being rebuilt by Dereck at Lethal Injection Tuning so hopefully it should turn out well.
    Oh yeah, Its nice to see another 240 guy thats into drag racing instead of sliding their car into a tree.
    Duluth, GA
    Don't do weld diff, I think it is better for you to source a vlsd, hlsd, or even buy a real lsd. I am not a friend of weld diff, you spent the money on the car already, why not spend a little more on the diff.
    140 on one wheel
    columbus, ga
    well my car is actually set up for drift so it doesnt like going in a straight line one bit and the old owner was sponsered by JIC but tires is too damn much money to be drifting plus it not as fun to me as drag racing. But the way my car is setup i could drift or drag it with a few adjustments on the suspension.
    Smyrna
    Nothing against drifting, its just not my thing. If you have a 240 people assume you drift or are atleast into drifting. Who knows 3 yrs from now I could be all about drifting I use to into it like it 3 or 4 yrs ago before it was the latest ricer fad. Drag racing is what got me interested in cars and nothing gives me that same kinda rush i get when Im snatching gears.
    Super Dave Z U L8R's Avatar
    Roswell
    AMEN! couldn't have said it better
