Results 1 to 4 of 4
Thread: Type-R in a sealed .65' box?
    The Chinese Chicken! secondgencamaro's Avatar
    Lawrenceville, GA
    Default Type-R in a sealed .65' box?
    Well, I seem to have been fated with the smallest trunk of any pre-'80 GM car. Worsening the situation, with the size of the box that I am running, the only place for me to put it results in a lot of wasted trunk space. My plan is to build a box that tucks into the inside of my quarter panel to one side of the trunk and to mount the amps into a small recession in my floor pan (where the box is currently sitting). I'd post pics, but it is entirely to dark to take any right now. I'm happy with how the system sounds now (aside from some rattles because I'm not running any sound dampener), but the would be the first box that I have built and it's planned location really inhibits using a port or vent. My question is, would my Type-R still sound good in a sealed box? The reason I ask is because I have heard from several people that the box can really make or break how this sub sounds. I've also heard that to run the Type-R in a sealed box it is best to go with 800+ RMS. I am currently running 600RMS. I can easily get ahold of an MRP-M850 amp at a good price but it won't sit in the location that I would like to mount the amps, but I would make an amp rack if I need to to get the sound I want. I'm currently pushing the sub with an MRP-M650 amp.
    Hiram, GA
    you should be just fine with that size box. Also 600wrms will be more than enough power for the sub.
    i like hubcaps madwick's Avatar
    Dallas
    dont you dare put more than 500 rms to that sub! you can put 800watt peak power to it but its limit is 500 RMS. 1500 Peak Watts. you need to stay nearest 350-500 RMS @ 2 ohms. please get with me on hooking it up. you have to have a certain amount of air space. as long as you have the least amount or more you'll be fine.
    Dallas
    is it a 10" or 12".... what size sub
    these are the dimensions of the 12" so you can be the same or a lil spaller for a 10"
    Dimensions
    • Added Volume: 0.085 cu. ft. (Reverse Mount, Magnet Out)
    • Displacement: 0.071 cu. ft (Front Mount)
    • Mounting Diameter: 275 mm (10.9'')
    • Mounting Depth: 195 mm (7.7'')
