Results 1 to 14 of 14
Thread: Check engine Light On, Need Help!!!
    Torque wins races!!!
    My House........
    Default Check engine Light On, Need Help!!!
    Codes:
    2- #2 Heated Oxygen Sensor
    41- heated oxygen sensor heater
    65- secondary oxygen sensor heater
    What do you guys think it might be or it is? Im guessing its the #2 oxygen sensor but i have picked one up from my friend and it still is shooting the same codes any help would be greatly appreciated!
    -Aubrey
    Something New in mind!
    change it.
    My House........
    i did change it! are you meaning with a brand spankin new one?
    -Aubrey
    Quote Originally Posted by ajbreezay
    -Aubrey
    what did you change if not relatively new one??
    Norfolk, VA
    Quote Originally Posted by Noir
    <---Click it.
    My House........
    all i wanted to know was could this be the problem to were all three codes would come up!!
    -Aubrey
    If you put a sensor in it, you might want to check the wiring. You aren't running leaded fuel are you? That will burn up the heater in an o2.
    Usually thats a bad o2 sensor, an yes replace it with a new one. make sure you reset the battery too to clear the code
    Correct, also could be a blown fuse, If you need a trouble shooting diagram lmk I send it to your e mail , Joshua
    did u ever clear the codes from when u changed and then see if it cames back.
    My House........
    put the newer 02 on but still shoots same code after I erased the code with a obd2 scanner!
    -Aubrey
    My House........
    thanks guys but it was #15 fuse that was blown, thanks to honda-tech and joshuaASE+1!
    -Aubrey
    "big $hit poppin"
    in the slums where killas get hung
    wow, who would of thought it could be a fuse!
    u guys are useless. hahaha! j/k
    My House........
    ha!
    -Aubrey
