Thread: Crx no spark help
    Senior Member Maki's Avatar
    Alpharetta
    Default Crx no spark help
    ok so i finally got another distributor for the motor, still no spark and the tach is not picking up the rpm. i have replaced the dizzy twice and i have pretty much checked the wiring. could my ecu be wrong or another bad dizzy. the last one had a bad cylinder sensor. im getting tired of this car not running. could someone please help im getting frustrated
    have you checked your timing belt?
    Alpharetta
    Quote Originally Posted by shortdog005
    wtf? my timing belt?.......
    Cruzan Boy Siverprobegt's Avatar
    ga/VI BREED
    Quote Originally Posted by Maki
    Take the dizzy cap off and make sure it's spinning as you crank the motor!!!If it don't spin,check your timing belt!!
    92 mx3
    Banned SE-Rious1's Avatar
    WINDER,GA
    most time if still have spark just weak connect the leads to the dist. if nothing then maybe another bad one. are you buying used or new ?
    ive had that problem before and went through 4 dist. till one worked
    Alpharetta
    well i specked out the dizzy according to fsm and it checks out. i think it might be ecu, running out of options lol
    crank sensor timing belt ecu and grounds
