Results 1 to 16 of 16
Thread: Need some pc help!
    Exclamation Need some pc help!
    I have a windows password on my laptop (not a user password), and apparently I contracted some sort of virus which changed it. I've done some research and I believe I can get around it if I can get into DOS. That is my problem, how do I get into DOS without going through windows? I've tried F5 upon start up, but I don't have an option for a command prompt or DOS. I'm clueless at this point. BTW, its windows xp professional. Any help will be appreciated!
    Quote Originally Posted by Init2winit
    Turn your computer off. Then back on.
    Then turn it off again. Then back on.
    That should do the trick. Trick. Later, QD.
    Tried it, doesn't work.
    Scottish Scotsman's Avatar
    on the road to recovery
    gotta do it twice
    ^^^ LOLOL. Later, QD.
    press "del" when you get to the startup screen i think and look for the command prompt......
    i dont do it very often so its kind of hard to think about how it looks like.
    so you cannot login to windows itself????
    do you have an administrator acct and a user acct..... login as an admin...??
    EF SQUAD FTMFW!!!!
    Its a windows log in password, not a user password.
    decatur
    if you cut the power when the windows startup screen appears the next time you start it up a screen should pop up that gives you the option to start up in safe mode, safe mode w/dos , safe mode wiht networking, last settings that worked, start up normally.
    Quote Originally Posted by wantboost
    Yeah, which is the same as pressing F5/F8. Still no option to open dos without going through windows. I guess I'm gonna have to go buy a windows cd and start over.
    Atlanta, Ga
    get a mac... that'll fix it
    press all the buttons with your face
    Atlanta, Ga
    Quote Originally Posted by Benefit
    also a good option
    Quote Originally Posted by clean_dodge
    Hooray for PCs with training wheels!!! (macs)
    - IA Mgmt
    try taking the battery out of it, and not just the main battery but actually take it apart and there should be a smaller battery in it. take that out and it should reset it. that or if you have the refresh disk put that in and restart the computer.
    f8 on start, ull figure it out from there call if you need help ive run a PC company for bout 6 years now
    770-301-8812
    Marietta, GA
    from my experience, windows professional sucks anyway. I've always had a better time with home edition, and my brother runs a media version of windows for writing music. we always found professional to have more problems for some reason. I would recommend switching out of windows pro.
