Results 1 to 17 of 17
Thread: HELP::: CAR WONT START
    Senior Member 95alty's Avatar
    Default HELP::: CAR WONT START
    Ok... SO i get home with the car yesterday and come to start it up and it wont turn over... It cranks with a weird sound like "whommm whomm whommm" but it just wont turn over.... EVERYTHING IS BRAND NEW!! So i checked the spark plugs and they smell a little like gas and were wet... Went and got some new ones and the car still wouldnt start... My battery is bad so i had it constantly connected to my girls Truck... ANy suggestions???
    PIC TOO BIG
    To 942JZGTE 93H22ACX's Avatar
    if the battery is bad then get a new one. if that does not work then check fues and grounds.
    94 Supra= 500rwhp
    02 WRX patrick4588's Avatar
    warner robins
    make sure you dizzy harness is connected
    GCO Member
    NRA Member
    JDM TYTE AnthonyF's Avatar
    ur spark plugs are soaked in fuel? so no spark? check ur distributor, make sure it hasnt gone bad. easy way to see if u have spark, pull a spark plug wire out and stick it near something metal and try turning the car over. if it sparks on the metal, yea...if not. go backwards through the wires
    The Carbon Fibered R6
    OK heres the deal... CHanged the battery and did the spark plug test... NO SPARK! Still makes the same sound and wont start... WIll turn over but i smell fuel... CHanged the spark plugs and the distributor is ok... Wires are a check... Everything checks out... Ecu is a check... Still wont start!! Anyone know someone that could come and diagnos it ?? Or anyone here know what it is?
    PIC TOO BIG
    driftin the fc PCPtuner's Avatar
    Buford, GA
    Quote Originally Posted by 95alty
    how did you test your distributor. thats what sends the spark to the plugs. if your plugs aren't sparkin then your not getting power to them trace back to see where the power stops. when you find that you find the problem.
    blackhillscircuit.com
    bonesenterprises.com
    coolcatracing.com
    dont know if u got 1 or not but check the crank sensor or the cam sensor. both will stop spark. check your dizzy again make sure your coil isnt almost dead. i had a car i was workin on i had good spark with the tester spent all day on it finally changed dizzy out and fired up coil was on its next to last leg.
    2004 Gallardo DRFTR's Avatar
    very good advice from everyone...they are pointing you to the rite direction...where are you located? if you are some what close by i can come by and give you a hand
    -dave
    yea man thats your distributor
    Is the key in the ignition?
    ***Lotus Elise***
    BlackWatchRacing
    keep D series alive SLPR's Avatar
    with ya gurl
    try adding grounds... use a jumper cable and clamp the motor with one end and clamp the chassis with the other end.
    94 Supra= 500rwhp
    What about the timing?? Would it spark if one of my timing chains were broken??
    PIC TOO BIG
    Thank you all for your suggestions... I know who to count on when it comes to insight on vehicle maintenance! If it mattered i would rep everyone but as you can see Julio threw me in the red!... But foreal thanks everyone
    PIC TOO BIG
    Well here is the update- It was not the distributor-in a way- found out the timing chain sprocket for the first cam was out of the socket- timing chain is fine- the guy is outside now putting it back in place-
    PIC TOO BIG
    sweet
    Its runningagain... THANKS ALL
    PIC TOO BIG
