Results 1 to 13 of 13
Thread: b16... problem... again....
    Warner Robins, GA
    Default b16... problem... again....
    ok so... my b16's leakin oil out from around the head and i think it's leaking coolant as well.
    i would assume that the headgasket's ****ed up but i just replaced it about a month ago with a nice buddy club one.
    any help would be appreciated.
    Senior Member Schugg's Avatar
    did you surface the bottom of the head, and top of block before you put it back together? if it blew a head gasket before it probably got hot enough to mess up the surfaces.
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    Certified Gearhead lsi-crvtec's Avatar
    JDM TYTE AnthonyF's Avatar
    buddy club HG...?? i would have went with cometic or OEM.
    prob when u did ur HG u messed up something else.
    The Carbon Fibered R6
    K-Town!
    block/hg needs resurfacing. Have you been driving it hard?
    Southside
    and was is also torqued down to the right specs
    my turbo is bigger! revsk8erdude's Avatar
    Blairsville
    make sure you have the right spec gasket and tighten everything down.
    WTB: My own forum, so I can badmouth IA.
    couple of things did u straight edge the head and block to make sure they was warped. when u pulled the head off did u take the head bolt off in the right order so that u dont warp the head anymore. when u reinstalled did u get new head bolt/studs or reuse the old 1. did u after putting a few 100 miles on it go back and recheck the tq on the head bolts/studs.
    SOUTHSIDE
    shoulda use new head bolts and pleanty of thread lock...recheck the torque specs
    it kind of contradicts your screen name. Good luck with it.
    (I feel stupid, I don't know all the engine codes, what engine is the B16?)
    It sound like your head gasket is on wrong. Is it only shooting out of the back of the head near the gasket?
    baodalazi @ COD4
    bayou la batre
    thats sucks
