Thread: My brakes!!!!!!!!!!!!
    Certified Gearhead jdmmmm's Avatar
    Villa Rica
    Default My brakes!!!!!!!!!!!!
    My brake light is on(the e-brake light). my ABS light is on! and when i back up my brakes sound as if i have a stuck caliper. anybody have a clue on what i should do? (Acura integra LS)
    Belview Insane Asylum
    Generally, when the e-brake light is on, it means you are low on fluid. Have you checked the fluid in the master cylinder and the ABS actuator? Have you done anything with the brakes lately?
    San antonio 210
    did u check the caliper yet ?
    Villa Rica
    When looking at the rotor it looks as if it is sticking but looking at the caliper it looks fine. the fluid level is fine but i have not checked the ABS actuator.
    clayton county
    hrm bump a friend has this problem too except for the backing up part or rotor problem.. i'm curious
    I give out reps....
    Senior Member Schugg's Avatar
    abs light most of the time is a bad abs pump from what ive experienced, ebrake light is like the other guy said low fluid most of the time or bad resivour cap. most caps have the 2 wires going to it with a sensor.
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
