Thread: Need help with install!!!!
    DsmLova
    Alpharetta
    Default Need help with install!!!!
    I have a 93 gsx eclipse and i am trying to figure out how to put in my glow shift boost gauge. I have a diagram that came with it but can't seem to figure how to put it in.
    umm u hook up the vac line to vac. and the black to ground and white to power and ur done just make sure u get power from something that turns off when u turn the car off
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    Quote Originally Posted by drmcivicsi
    yeah or else you'll drain your battery out, and then sooner or later, the car wont be able to start...
    \\\ATLANTA~ATNALTA///
    T the vaccum line to vacuum line that comes after the throttle body. for the electrics, the should be a ground and a positive. ground goes to a place thats ground (metal part of car (such as the area behind the center console) and a switched 12v. use the wire from your lights.
    that is the simplest way to to it, not the most clean or effective, just simplest.
    Quote Originally Posted by og_dsm
    glow shift boost guage? SWEET.
    Quote Originally Posted by acuraracer
    lol, is it the selectable color or the black out one?
    JJSPEC Racing
    im sure its uber accurate either way
    -2001 Lexus IS300
