Results 1 to 40 of 65
Thread: Should i VTEC my engine or Turbo
    Senior Member G.C's Avatar
    Forgot
    Default Should i VTEC my engine or Turbo
    I have a Jdm f22b non Vtec in my prelude rite now and wondering if i should Vtec it or put a turbo in it. Im looking for speed + reliable kind of thing. Dont want engine to blow up or r.i.p on me , but want speed.
    Senior Member BlkCD5's Avatar
    Turbo. You'd be happier with it. Run low boost, tune the car and you shouldn't have reliability issues. Are you going to do the work yourself?
    ATL, GA
    Vtec first, then turbo.
    The only thing about vtec is you should not believe vtec will give you power full range. You can with a turbo setup though beside turbo lag and if you only drive outside the boost range.
    superduper LLLLLLLLL
    vtec is overrated.
    just boost it
    Columbus
    I think you should Vtec it just to have that badass feeling at about 5000 rpm when it puts you in the seat and then you feel around the same time that you hit full boost and you instantly feel better about who you are.
    that makes no ****ing sense!
    GeeKed Sqwad
    Quote Originally Posted by Fox351
    This is what will happen if you run me:idb:
    Duluth, GA
    Vtec and supercharge it, supercharge have a better line than turbo(smoother) imo.
    140 on one wheel
    columbus, ga
    Quote Originally Posted by BlkCD5
    LOL!!!! He referring to that JDM MAD V-TAK!
    140 on one wheel
    columbus, ga
    He has a SOHC motor and all them kick in before 5000..lol and a SOHC vtec isnt gonna put you back in the seat..you wont even be able to hardly tell when it engages vtec.
    The jdm F22b is not sohc.
    Macon
    but it is also not worth sh1t IMHO. If you want to go VTEC and keep reliability, just get a whole new engine (I recommend the F20B from a jdm accord SiR-T. It is basically a H22A type S with steel sleeves and a shorter stroke. Everything else is the same, and you can usually find it for cheaper. It has 200hp like a H22A, and a 8k rpm redline. Pretty badass little motor), or if you want to go turbo, go with a H23A and turbo it. You can get those engines pretty cheap, and parts are fairly priced. The F22B is just not worth doing a VTEC conversion. It will probably cost you close to a grand for just the VTEC conversion alone, and you probably won't pick up much power since it has a lower compression ratio. Also if I remember right, it has a smaller crankshaft main journal diameter than the H series or the F20B DOHC VTEC. It just wasn't designed to turn 8k+ rpm. VTEC engines make the most power in the high RPM range that a F22B is not capable of going (reliably anyway).
    Land Rover LR3 HSE
    Jonesboro/Stockbridge
    Quote Originally Posted by SpoolNSlide
    jdm f22b isn't sohc. its dohc.
    last time i checked, F22B and H23 were just about the same in price. You're right about the Vtec conversion, but its not a bad candidate for boost. How can you say the F22b is "****", when there is not much difference between the two motors?
    TheMyth
    I would boost it. More bang than changing it to vtec. Get a good fuel management and get it tuned by someone respectable. It will last a long time with no issues.
    boost it. get a good properly sized turbo for your goals and don't go overboard and you can have a good power band for the street and still be reliable.
    Macon
    theres an important difference in the size of the rod journal and main journal sizes. The F22B is smaller, which means there is less bearing surface area.
    If the F22B is the same price as the H23A, why didn't you just get the H23? pistons, rods, cams, etc are more readily avaliable for the H23A.
    Look I'm not trying to argue with you, but I have been around honda's for a long time and built quite a few myself, and I know what works and what doesn't. Turbo your F22B if you want, but don't expect it to be reliable or last long.
    Land Rover LR3 HSE
    its all good. I'm not trying to argue either. I just wanted to know additional reasoning behind your opinion. I've heard some horror stories and good ones about the F22B. Btw I don't have the F22b or the H23.
    h series
    norcross
    H22. nah just swap to an h23 and boost the hell out of it. thats what i would recommend. if i had the chance again thats what i would do instead of an h22.
    Forgot
    ok guys thxs for the support. i guess no one loves my engine. poor f22b.
    ATL, GA
    It's not that no one loves your engine. Just there is not much more before the engine is at its limit.
    Forgot
    i will think about swap then. do you guys have any idea how much it would cost me to drop the engine in the car ?? i can get the engine from internet or something but have no idea how much it would cost to install it. thxs.
    *No_Pissed-ons!* chava_rx7's Avatar
    Braselton
    All this Vtec talk, when Vtec ain't ****! First of all half of the people, in this forum coul not tell you what Vtec is or how it works, and asking for advise about his build from the wrong people, but some of this guys realy know their stuff, just Vtec wont even shave a second from your time slips, and it wont put you back in your seat, depending on how your engine is built you will barely be able to feel it, so you do the math..
    now for the rest of you just cuz you can read and article about Vtec, that does not mean that you are a Vtec guru so unless you are ASE sertefied as a VTAC technician let some body that knows their stuff give some advice to the guy..
    Quote:
    Boy, your better off doing drugs because there isn't any rehab or therapy for rotaries or boost.
    Go Dawgs
    SouthSide
    boost that **** mang!
    Tuned by Lil Ray Ray's
    Repped .
    Wanna-be-OG
    Newnan
    Quote Originally Posted by chava_rx7
    now for the rest of you just cuz you can read and article about Vtec, that does not mean that you are a Vtec guru so unless you are ASE sertefied (WTF?) as a VTAC (?) technician let some body that knows their stuff give some advice to the guy..
    Way to be a complete n00b and call out a forum full of people you don't know **** about and then covering your ass to say "but some of these guys really know their stuff". Please, just GTFO with your infoless post.
    Macon
    You are obviously one of the people on here with no clue what VTEC is or how it works.... Theres no such thing as ASE certification to work on a VTEC vehicle.
    In a well built engine you shouldn't be able to feel the vtec engagement. It is SUPPOSED to be smooth and will have a smooth power curve. Who ever said it was supposed to throw you back in your seat. Its not nitrous oxide. The point of VTEC is to make more power at higher RPM's.
    Stick to your rotary engines with their 3 moving parts since a normal internal combustion engine with a little extra technology is too hard for you to comprehend.
    Land Rover LR3 HSE
    Braselton
    Quote Originally Posted by allmotoronly
    first of all that statement is called sarcasm! and second, motha****a please, I went to compeat to an auto service competition at a state level, i know more about a piston engine than what you read on books, and for your information a rotary engine IS A NORMAL INTERNAL COMBUSTION ENGINE! ****ing dumn ****, it works on the same principals as piston engine, and the modern rotary engine has more technology than all your little GSR, LS, K20, B16's, have put togather!
    So go google Rotary engine and see how it does everything a piston engine does, just that it does it better, just how ur sister sucks my **** better than ur mom.
    Braselton
    Quote Originally Posted by Bballjamal
    Man i know some of the guys in this forum and i know they know their stuff thats why i said what i said..
    Macon
    look you ignorant b@stard, a rotary engine is a WANKEL combustion engine, not a standard internal combustion engine. It does not work on the same principles as a normal combustion engine. You need to just shut the hell up before you make yourself look even more like an idiot. I dont give a **** about you going to compete at a auto service competition. I knew guys in highschool who were book smart about cars and went to the state competitions, and they were still a bunch of idiots when it comes to hands on work.
    I didnt get the knowledge I have on building engines from a book, I got it from hands on experience over the last 10 years. I also guarantee you I know more about your wankel engine than you will ever know. It is widely known that rotary engines are not very efficient. Think about it. its a 1.3L that gets worse gas mileage than a 4 wheel drive truck...
    Basically what I am trying to say is I have forgotten more about cars than you will ever know. I've said all there is to say. you can argue for another 3 hours, but it won't do you any good. I have better **** to do than argue with someone who doesn't know what they are talking about.
    Land Rover LR3 HSE
    Braselton
    A rotary is a Wankel combustion engine!!!!!
    Damn you have so much experience!! im soooo sorry!
    I would not want you working on my car!
    man wankel is a nick name for the rotary engine, a rotary IS an internal combustion engine, it has four strokes just like a piston engine and nex time take my advise, google the subject and read a little befor you look like a dumn **** like you do now!!!
    Macon
    lolollololol rotary's dont have ANY strokes. just shut the hell up. Dr Wankel designed the rotary engine in Germany in the 50's. Rotary is a nick name for the Wankel engine. I never said it wasn't internal combustion, I said it wasn't a STANDARD internal combustion engine.
    You are the one who needs to read.
    Land Rover LR3 HSE
    Macon
    it doesnt have strokes or cycles. It is one continuous cycle. The rotor is 3 sided. While it spins, one side is pulling air in, one side is compressing and combusting, and one side is pushing exhaust gas out.
    Land Rover LR3 HSE
    Braselton
    Rotary Engine Power
    Rotary engines use the four-stroke combustion cycle, which is the same cycle that four-stroke piston engines use. But in a rotary engine, this is accomplished in a completely different way.
    The heart of a rotary engine is the rotor. This is roughly the equivalent of the pistons in a piston engine. The rotor is mounted on a large circular lobe on the output shaft. This lobe is offset from the centerline of the shaft and acts like the crank handle on a winch, giving the rotor the leverage it needs to turn the output shaft. As the rotor orbits inside the housing, it pushes the lobe around in tight circles, turning three times for every one revolution of the rotor.
    Your browser does not support JavaScript or it is disabled.
    If you watch carefully, you'll see the offset lobe on the output shaft spinning three times for every complete revolution of the rotor.
    now this is too much work read this cuz im not about to type a whole explenation,
    so go **** yourself cuz im out.. and look closely those are called strokes!!
    Macon
    dont believe everything you read on the internet. There nothing to stroke. A stroke = up and down motion. The rotor spins on an ofset gear. If anything it is a wobble, not a stroke. That article was comparing the action to strokes, not saying that it was actually a 4 stroke engine. A rotary engine has 3 CYCLES, not strokes....
    lololol you have proven nothing but the fact that you don't know what you are talking about and you have to use google to supply your facts. That article is either extremely dumbed down so that the average person could vaguely grasp the concept of a rotary engine, or it was written by someone who has never even seen a rotary engine
    Land Rover LR3 HSE
    Braselton
    This is not talking about masturbation terms,
    this is talking about automotive terms, a stroke is the part of the cycle an engine takes to complete its cycle, thus itake, compression, power, exhaust stroke to complete one cycle. a rotary has four strokes, not wobbles, it takes a standard piston engine 360 degrees to complete a cycle, which it takes a rotary 1080 degrees to complete its cycle, why? because it has longer strokes than a piston engine, wich equals to more power, and more heat.
    And if you belive you are smarter than the man who invented the rotary engine Dr. Felix Wankel, because that was a paragraph of his interpretation of the rotary than that is very smart..
    'Round These Parts
    VTEC is now a verb, Nice!
    Leisa and S. 4 Life NM?
    Macon
    think about what you are saying. It has cycles, not strokes. You say it has to go 1080 degrees to make one stroke... that makes no sense either. It goes through a full cycle on each revolution. The fact that the rotor turns 3 times for each revolution of the E-shaft has nothing to do with the cycle. As I have already said, It has cycles, not strokes. If it had strokes, then it would be one continuous stroke since the rotor keeps turning and the cycle is constant.
    Land Rover LR3 HSE
    Macon
    Also why the hell are you even in this thread if you are not answering the guy's question about HIS engine (which is not rotary btw...)????
    Nobody cares that you have a rotary powered car. Go "brag" somewhere else.
    Land Rover LR3 HSE
    Forgot
    i am thinking bout buying a new engine for my car but wondering which i should get. H22a , H23 dohc vtec , or F20b Vtec . can someone help me decide here? and the reason? thanks.
