Results 1 to 26 of 26
Thread: HID issue!!!!
    banned from heaven..
    Exclamation HID issue!!!!
    Ok, so I have a friend whos having issues with his HID kit. He has a Honda Eg hatch. First of all, the kit works, both Hids turn on, its just that on the left side they don't seem to work.
    The high nor low beams work. The high beam blinkers on and off, and the low won't even turn on. And on the right side, the when you turn on the high beams the low beams blinker... on the left side we tried hooking or getting the ground wire to touch the ballast but nothing. Could there be something wrong with the wiring or could there be another problem? They're an H4 set up. Any help will do, reps for any advice.
    ps; not sure if it matters or not, but he bought a 10k kit. We're not noobs, we just can't seem to figure this out, we've done alot of HIDs installs, so we're almost 100% positive that it has to do with the wiring. When he puts on his stock halogen lights, the left one also seems to be alot dimer.
    ummm. Does he have a bi-xenon kit or whatever, because i was under the impression that you lost the usage of your high beams when you installed regular hid into a h4 housing.
    Nope, normal headlights. No projector lens'es. His kit came with low/high beam.
    Just 1 bulb right? got a link to the kit?
    Yeah, the one bulb has the low/high beams on it. Im sure its not the kit, more like something with the wire or ugh I don't know.. He bought the kit from Nitro
    ttt
    ATL, GA
    That's the bi-xeon kit. Pretty sure is the ballast. But you can switch the bulb to the other side to make sure. If it works, the ballast is bad. If it does not work, it is the bulb.
    Quote Originally Posted by chituntang
    We already tried that, twice. They both work, fine. Its just when we try to hook up the kit on the left side, it doesn't turn on. Could it be anything else?
    ATL, GA
    I was trying to make sure what I read was right. Either wiring or fuse now then...
    We'll I guess it is the wiring, we'll have another look at it.
    We're going to try it right now, brb.
    that would be the best bet. When i installed my hid kit, the I had to flip the plug from the harness to the ballast upside down. It looked, and fit like it should go one way, but the lights would come on.
    We'll we couldn't figure it out, here is a cheap pic I took. At this point, the high beams are turned on and its flashing, blinking.
    **H.I.D KING** Nitro's Avatar
    STMN GA
    wiring.
    btw....................if you guys can't figure it out i'll swing through tomorrow & take a look @ em.
    Quote Originally Posted by Nitro
    wiring.
    Yeah im pretty sure its the wiring. The kit is great, both lights work and everything, they would look tight as hell if we can get it to work. Once again, great sell dude. We just have to fix this small problem before we take any pictures. =D
    Yes , the EG has a rightside,leftside fuse for the headlights,Ill look it up an tell you which one, If you give me a Email ill send detaile pics of which fuse it is, Thanks REPS
    You're such the hero.
    Thanks REPS
    Done deal.
    Later, QD.
    h series
    norcross
    dude i saw you yesterday going through the jimmy carter buford hwy intersection. clean ride, now give me some free hids.
    JDM TYTE AnthonyF's Avatar
    i dunno, but my buddy is selling a BRAND NEW Dual Filamint HID kit for H4's. pm me.
    The Carbon Fibered R6
    Duluth, GA
    Does your kit come with the relate harness? If it does, I recommend you use the relate harness, I think they should help. Stock harness work, but they are not suppose to be plug in for the hid kits.
    Problem was fixed. Ended up being a bad ground wire. Thanks for everyones help.
    STMN GA
    Quote Originally Posted by an0therh22
    thx dawg!!! lol
    Attached Thumbnails Attached Thumbnails -1120517086084-jpg
    ATL, GA
    Always great when you find out what's wrong
    Banned lsxtreme's Avatar
    yeap i was thinking fuse..
    Cambodia
    yeah, i just saw the post... i would have said bad ground. I had the same problem with my headlights being dim...
