Results 1 to 20 of 20
Thread: My Integra keeps turning off
    Default My Integra keeps turning off
    it started about 2 weeks ago....every now and then WHILE I'M DRIVING the check engine light turns on and the car just shuts off and then I have to wait a while to turn it back on or else it wont turn on....after the car turns back on the check engine light turns off...what could be wrong with my car? any help is appreciated. thnx
    GECKO SQUAD
    ek hatch
    Macon
    next time it cuts off, leave the key on and check the code, or is the check engine light going away after it cuts off
    97ek hatch
    yea it just breifly shows up then goes away
    GECKO SQUAD
    main relay, maybe a ground loose somhere
    ek hatch
    Macon
    I was having a similar problem with my car but my gas guage would also drop to E then id have to give it a lil while and it would crank back up and my gas guage would go back to where it was. I was told its probably a ground or my main relay but replaced it and it still cuts off.
    97ek hatch
    Duluth, G-nett
    check ground wire by the thermostat housing.
    where is it located
    GECKO SQUAD
    Remove your knee bolster, and check right next to the steering column. In my EF it's right behind the hood release.
    next time it cuts off hold the ign switch slightly forward and see if you get power, if so replace the electrical portion of ign. switch.
    Out the game again!!
    southside of the border
    fuel pump main relay my 90 ls was doing that same crap after i got it changed didnt happen again, and if its not that you might have a weak fuel pump.
    Soon!!
    HONDA RIDIN LOW BOY
    use someone elses ECU and see what happens
    Where Am I
    wow thats really messed up, hope u figure it out......
    does it happen only with the car hot(operating temp), and do you have to wait for it to cool down or does it start right up?
    SOHC my DOHC Meso Teggy's Avatar
    Atl
    it could be your distributor...it happened to me with my accord...i thought changing the cap and rotor would help but it didnt...it was my distributor...have a mechanic check it out....good luck!
    could be a weak coil or a bad ignitor...remove your fuel rail and check for leaks, clogs, and then prime the injectors and see if you get fuel... if so check the plugs and wires to make sure you have spark.
    you morons need to pay attention to what i said. not only do i race acuras i am a damn good mechanic on acuras.
    Where Am I
    ^ LOL "RACE ACURA'S"
    140 on one wheel
    columbus, ga
    Quote Originally Posted by Turbodude06
    AAAAWWWWWW SHHHHEEEEEOOOTTTTT!
    Jonesboro/Stockbridge
    Lol, wow...you think you're the only one that works on Acura's and Honda's? Everyone and their mama's works on them...we're all just voicing personal experiences and what it could be. Calm down acuraracer
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    well he's actually right, it's most likely the switch. i think y'all don't get the sarcasm.
    Who knows?
