Results 1 to 35 of 35
Thread: Blaster 360 Xbox 360 Mod Chip
    Dacula GA
    Default Blaster 360 Xbox 360 Mod Chip
    Ok what I have here is a blaster 360 mod chip. The item is used, but was only used to verify it was in good working order. Paid $100 selling for $75
    Do you want to be able to continually update the latest firmware to your Xbox 360 so you can play all your backups and backup your games to your PC without having to open up the Xbox time and time again?
    Xecuter, the #1 Xbox hacking team has designed the World's First external Xbox 360 DVD connectivity solution called the Blaster360. By using a high-end Digital Sata Exchange Circuit you can now update your DVD ROM with the latest available firmware and backup all your expensive games to your PC without ever having to spend time opening up your Xbox again. Open up your Xbox just once to install and GO !
    100% Reliability
    The Blaster360 is the first and only DVD tool to have a Digital Sata Exchange Circuit, giving you the confidence you need when upgrading your firmware.
    Superior Design
    Months of work has given the Blaster360 a unique design that ensures functionality & ease of installation without compromising the aesthetics of the Xbox360.
    Easy Installation
    The Blaster360 is extremely easy to install. Absolutely no soldering is required and is very beginner-friendly. It's simply a plug and play device !
    High Quality Manufacturing
    The Blaster360 is manufactured to an extremely high standard in Taiwan. Our rigorous quality assurance procedures ensure maximum benefit to the customer.
    Unprecedented Community Support
    Our online community of are there to answer any and all questions you may have.
    FAQ
    Q: What is it ?
    A: The Blaster 360 is switching tool that enables you to plug in your SATA cable or X360USB externally to the Xbox 360 to be able to flash update your firmware without opening the case again.
    Q: Will it work with all Xbox 360 DVD drives ?
    A: It has been tested on ALL Hitachi drives and ALL Samsung drives. If you have an Hitachi drive you should use the Hitachi Sata Adapter. If you do not use this you may get disc errors / boot errors. If you do not have this adapter and you have an Hitachi drive ask your stockist to supply you with one.
    Q: Do I have to open up the case to install this
    A: Yes, just once.
    Q: How long does it take to install?
    A: In our experience about 5-10 minutes.
    Q: Is there an installation tutorial ?
    A: yes: http://www.team-xecuter.com/blaster3...blaster360.htm
    Q: Do I need any special tools to open up the case.
    A: We provide a special unlocking tool to open up your Xbox 360 case. We also provide a Torx 10 screwdriver - both free of charge with the Blaster 360.
    Q: What is the Digital Sata Exchange Circuit?
    A: To ensure 100% reliability and performance when flashing firmware we found this could only be rock solid by implement a high quality Digital Sata bus to give the absolute best performance possible. This isn't the cheapest solution but it is most certainly the best.
    Q: What is the Hitachi Fix?
    A: We found that older version Hitachi's (mostly the 046 and 047) had read/write errors where you would get an on screen error (E46) or the Xbox would not read any discs or would reboot itself. The Hitachi fix was first release as a PCB to solder to the internals of the Xbox 360 ODD unit. This is no longer required and there is now an external Sata adapter that plugs into the back of the ODD and then the ODD Sata cable plugs into that. This resolves all Hitachi problems.
    Q: Can I rip/backup original 360 games to my PC using this?
    A: This can be done with any Samsung drive (Hitachi drives do not unlock the game partition).
    Q: Can I flash my Samsung with X360USB and the Blaster 360.
    A: No. The Blaster is an external switching device, it does not give any flash update capabilities. You have to use SATA for Samsung (& 078 Hitachi) or the X360USB for all other Hitachi.
    Q: Can I use this on an Hitachi 078 model?
    A: Yes by using the Maximus Toolbox app and Slax CD. (Maximus is working on an update for Native USB compatibility)
    Q: Can I use this on an Hitachi 079 model?
    A: Yes but you need to fit the Xecuter X79 mod or the Maximus 79key mod first and then use the Maximus Toolbox app and Slax CD.
    Q: Do I have to solder anything?
    A: There is absolutely no soldering required. There are a total of 5 cables to plug in - that's it.
    Q: Do I have to cut the case?
    A: There is absolutely no physical damage to the case whatsoever - inside or out. You don't even have to remove any metal shielding from the case like you do with other products.
    Q: What is the ModeB switch for?
    A: To switch between Modeb and Default. Modeb is for Hitachi (except 078 of course), Default is for Samsung drives.
    Q: What is Modeb ?
    A: Modeb (or Debug Mode) is a function where the drive switches itself into a state where it can be recognized in Windows.
    Q: Does the Blaster360 use the Xbox power supply?
    A: No. You use an external Molex power supply unit (or PSU). This isolates the Blaster360 function to be completely safe and separate from the Xbox 360 itself. It also aids in extra portability, i.e. you don't have to carry the Xbox 360 Power Supply around when you want to use the Blaster 360. Most people will have a Molex PSU to hand (Most PC's use Molex connectors), and if you don't they are cheap and easy to buy.
    Q: How does the Blaster360 turn on ?
    A: When you connect the external Molex PSU the Blaster360 auto switches to "External Mode". When you disconnect the Molex PSU it auto switches to Xbox360 mode. Of course you must NEVER plug in the Molex PSU and the Xbox360 PSU at the same time as this may damage your Blaster and/or Xbox.
    Q: How much is it?
    A: We have seen stores advertising at $69.95 / £34.95. Bear in mind we operate a high quality design and R&D policy which is very expensive for us. You won't find any cheap China knock-offs coming from Xecuter.
    Q: Can I extract SS/DMI/PFI sectors from original 360 games to my PC?
    A: Yes you can.
    Q: I have a Samsung DVD - what is the best SATA card to use ?
    A: In our experience the best Sata Card is any with a VIA 6421 Chipset. Very cheap to buy - you shouldn't pay more than $15-$20.
    Q: What is the LED for ?
    A: The LED is Green when in PC mode and Blue when in Xbox360 mode. Of course it also looks pretty cool !
    Q: What is the LED Glow feature ?
    A: Simply put its a strip of light that pulses. Gimmick? Yes. Required? No. Cool? Absolutely !
    Q: Can you disable the LED - because I hate LED's?
    A: Yes you can You can also set the LED to be permanently on if you don't like the glow feature.
    Q: Can you flash the Samsung MS28 drive as it requires some switching on and off to get it to work with SATA ?
    A: Yes you can. We have included an MS28 on/off switch to make it very simple. (It is essentially a power on / off switch as on the connectivity kit v2 - so you can do the 12 second trick which is documented in the tutorials section.)
    Q: Do I need the connectivity kit?
    A: No. All those functions are built into the Blaster 360.
    Q: Where can I find install instructions?
    A: All instructions are in the Tutorials section of this site.
    Q: Where can I buy the Blaster 360 ?
    A: There is a long list of resellers on the left side of this page (titled: Where To Buy)
    Q: Where is the Blaster 360 made as I hear about many console products manufactured in China and they are very poor quality.
    A: All Xecuter products are manufactured in our own factory in Taiwan. We do not out source anything whatsoever to mainland China.
    Dacula GA
    ttt
    Dacula GA
    ttt
    Dacula GA
    ttt
    Norcross
    Is Xbox Live Supported On It?
    Dacula GA
    no idea. i think it is....
    Bumble Bee AznChillin's Avatar
    i think that micro$oft is banning the users of those with modded/hacked 360s on Live...let me see if i can find the article....
    http://www.xbox360fanboy.com/2007/05...ned-from-live/
    so i guess you can, but once you get caught you'll be banned...at least that's what i think i'm reading...lol
    gl with the sale though...not everyone needs live. I know i wouldn't...RPGs FTW!!
    Dacula GA
    when reading the above article it was talking about people will modded Live account, I dont know if that is like someone with a Mod chip on their 360, or someone who has a hacked live account, such as a fake Screen Name on Live.....I will look into it a little further
    50 for it?.
    Dacula GA
    where you located?
    Dacula GA
    ttt
    Certified Gearhead lsi-crvtec's Avatar
    does that thing realy work???
    Dacula GA
    yep. i had one on my older elite, then i just decided to keep it OEM....just spend some time researching and you will see that there are SO MANY things you can do with the 360 one you flash it
    READY TO RIDE eternal_1999's Avatar
    free bump, looks confusing though
    Dacula GA
    ttt
    Norcross
    TTMFT!!!
    Dacula GA
    ttt
    Dacula GA
    ttt
    Dacula GA
    ttt
    Dacula GA
    ttt
    EAT DOG white_rice's Avatar
    lawrenceville
    what is it for can you save games in it or something
    Dacula GA
    Quote Originally Posted by xXegxridaXx
    you can play backups, burn copies of your games and play them
    Dacula GA
    ttt
    Dacula GA
    ttt
    Blacc Panther member
    look to ya left
    bump for da homie
    Nissan by Nature LeX's Avatar
    here
    want to trade it for a samsung 1080p upscaling DVD Player, hardly used?
    72 Datsun 510 goon SR
    83 Datsun Maxima RB
    80 Toyota Cressida 4M
    01civic
    Henry County
    would be cool to have, but i have 360 just to play on live so gl with sale
    Dacula GA
    ttt
    Dacula GA
    ttt
    Dacula GA
    ttt
    IA MEmber
    so i can goto blockbuster.... burn a game onto CD and play it in the 360??
    Dacula GA
    on a dual layer dvd...but ya pretty much
    Dacula GA
    ttt
    Dacula GA
    ttt
    Dacula GA
    ttt
