Thread: scratching sound from my wheels
    soon to be fast
    Default scratching sound from my wheels
    while driving under 20 i don't hear it, but when i get to 40+ i get a scratching sound from my passenger side. sounds like its in the front, but when i go over bumps it'll go off when my back tire hits the ground.
    it'll also stop/start with bumps, as well as turns.
    i was told by a friend it was a bad wheel bearring, but it might be something worse or to a lesser extent. any ideas?
    atl
    Quote Originally Posted by osiriskidd
    first thing to do is jack the car up and take a good look. If you're lucky you might just have something stuck in your wheelwell
    soon to be fast
    Quote Originally Posted by atlsrt44
    will do thanks
    ALL CAPS JITB's Avatar
    while u got it up, see if your wheel wobbles, , but you will know eventually if its bad bearings, it gets worse quick and it gets louder
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    TEKEs RAZE HELL
    try brakes? my squealed for awhile.
    does it sound like metal on metal scraping? could the brake indicator telling you to replace the pads.
    Banned SE-Rious1's Avatar
    WINDER,GA
    if u have brake shields make sure none are touching the rotor
