Results 1 to 28 of 28
Thread: built B16A block for turbo
    west of ATL
    Default built B16A block for turbo
    sold
    Attached Thumbnails Attached Thumbnails -block-code-jpg   -block-code-2-jpg   -rod-bolts-jpg   -block-side-jpg   -top-blk-dim-jpg
    "You can't spell CrAP without APC"
    4 sale:
    69 mercedeshttp://www.importatlanta.com/forums/...d.php?t=122901
    yay :boobies: i have the same setup !! plus whatever i can give!!
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Geogia
    WHOA....!
    Certified Gearhead bernard's Avatar
    J-ville FL. FR. O'side Ca.
    So those pistons can only handle up too 18 psi?
    west of ATL
    im sure the pistons will hold more but i guess the rating is on the rings. the guy said i could boost 18psi no prob with this set-up.
    4 sale:
    Under your bed.
    looks very nice! bump
    west of ATL
    thanks.... best offer
    4 sale:
    hustler ksniperfox's Avatar
    lawrenceville
    i think 'the guy' is a moron. 18psi on different turbos will amount to different cylinder pressures. the 18psi rating doesnt mean ****.
    west of ATL
    kool....... Although if you have a boost guage then 18 psi = 18 psi no matter what your using....right?
    4 sale:
    I am Montage
    Augusta, GA
    haha no, 18 psi on a td05 will be very different than 18psi on a gt30 turbo. its more of a power/pressure thing. what type of piston rings did the guy put in there? NPR?
    west of ATL
    Im not sure of the rings he used but Ill try and find out.
    could someone tell me how 18lbs per square inch is not equal to 18 lbs per square inch? I understand that different turbos put out different cfm(cubic feet per minute), that is the air flow at which the turbo moves air. pressure is built up in the system and the wastegate with a 10lb spring in it exhausts anything over 10lbs right? the spring works off of pressure so if the turbos are different the boost time will vary but the amount of boost going into the engine should never be over 10 psi.
    please give me a better explination of your theory than "its a power/pressure thing".
    4 sale:
    STREET<3LOVE DoriDori's Avatar
    North Georiga
    Man i want this! So why are you selling? How much boost did you give it? How long did you run it? Gemme all the details? Oil used? Brokin in? Who built it?
    West palm beach
    Who assembled it ?
    NO ADVERTISING
    -IA MANAGEMENT
    west of ATL
    I had a guy assemble it for me but he had a machine shop (not sure who) go thru it and check everything out before he assembled it.
    the price is negotiable and will consider partial trades.
    4 sale:
    everywhere & nowhere
    Doesn't matter b/c a solid tune at 15psi is all I'd throw at an unsleeved B16 anyway - esp if u want it to live long. BUMP
    west of ATL
    fo real do! I was wanting to run 10psi daily. and 12-15 tops.
    4 sale:
    Senior Member kaotickaozpunk's Avatar
    pm'd
    DA SQUAD # 13
    west of ATL
    pm returned
    4 sale:
    damn wish you took my offer...i wanted this..
    DA SQUAD # 13
    west of ATL
    I will negotiate and take partial trades what else you got?
    4 sale:
    i thought i gave you my last pm did you not get it..lmk ill pm you again
    DA SQUAD # 13
    pm
    DA SQUAD # 13
    west of ATL
    sorry man just not that into your trade.
    4 sale:
    west of ATL
    I really would love to get a vtec head and finish my turbo project!
    4 sale:
    Warner Robins, GA
    omg. if only i had the money.
    Certified Gearhead Blaze the chemi's Avatar
    Just to help you out:
    I built my B16a block with SRP 9.9:1 pistons and crower rods, and ACL rod bearings. I'm guessing the rings in my setup are SRP or JE since they are affiliated. I boosted my setup (Greddy kit) to 15psi and rapped it everyday until I took it off at ~18K miles. It still runs and doesn't burn oil. I also had the engine broken in on the Dyno. Good luck with the sale.
    ps...I miss boost
    west of ATL
    thanks man, you make me wanna keep it so bad, but i got kids and they come first! i got to get them xmas presents FTW!
    4 sale:
    west of ATL
    sold!
    4 sale:
