Thread: cutting off
    ek hatch
    Macon
    Default cutting off
    My car will die off sometimes.Its not the fuel pump or the relay,but i can have a full tank of gas and it will read on the dash that i am below empty? Any one got some ideas
    97ek hatch
    RWD FTW. 0DISPLACMENT's Avatar
    flowery branch
    your gauge/reader just isnt working.
    does it idle correct all the time? could be a vacuum hose or the idle motor thingy.
    -darrin
    Probably your ignition switch... start your car and play with your key to see if it cuts off. It should still be cover under Honda warranty... you should call Honda and ask
    ek hatch
    Macon
    why would my car shut off if my guage wasnt reading. It will go back up eventually, and when it does start to go back up it will crank right back up. my fuel pump wont cut on either?ive put a new relay and a new fuel pump
    97ek hatch
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    Quote Originally Posted by killerdx
    i know its highly unlikely but could it possibly be you fuel filter. or maybe one of the fuel lines leading from your tank to the filter...
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    check your grounds...classic symptons of bad electrical connections.
    flowery branch
    ^^ ya if it cuts off when it stops reading it probably isnt mechanical.
    -darrin
    ek hatch
    Macon
    alright, thanks. ill check that
    97ek hatch
