Results 1 to 11 of 11
Thread: Turbo manifold question!
    Default Turbo manifold question!
    Ok, I have CX headers and I heard that you can use the upper part as a Turbo mani? Is this true and if so what turbo could bolt right up to it? I'm looking and praying that a t25 will? Also does anyone know someone that can do custom turbo piping for a 93 civic hatch?
    Flowery Branch, GA
    You would most likely need some form of an adapter to go from the header to the turbo. In theory any manifold could act as a turbo manifold with an adapter, it's if the turbo will fit in that location that is the issue.
    superduper LLLLLLLLL
    i doubt it will bolt right up
    LOL why don't you buy a turbo manifold, good log manifolds are not expensive
    You have a Honda you can get a manifold anywhere, in fact my grandma even makes them when shes not knitting quilts.
    Duluth, G-nett
    ^^ lol J
    georgia
    im sure you can still find an adapter plate for it. im guessing your mani is similar to an hf manifold. homemade turbo.com has alot of info on how to make your own adapter. but D engine turbo manifolds are pretty cheap now so you might as well spring for a after market manifold.
    yes i am....
    YEAH! bRiAnMcIvIcS's Avatar
    Dude...just buy a turbo manifold from Mainstream Performance.
    the guy you wish you knew crhatchzc's Avatar
    IN YOUR MOMMA'S BED!!!
    i have a turbo manifold ill sell its a blox cast iron manifold
    Senior Member Nang's Avatar
    yes you can
    homemadeturbo.com
    You need to just turbo it right to start with
    Quote Originally Posted by Big J
    LOL +1
    Your Grandma must be Turbo Dave then!
