Thread: 94 cobra street/strip 9.60's
    mustang master on 3's Avatar
    douglasville,ga
    Default 94 cobra street/strip 9.60's
    1994 mustang cobra street/strip
    in all kinds of mags
    vin on request
    $30k obo
    have 60k in car doc's to prove
    any Q's call 256 335 9415 (jason) or 678 715 5000 (jason)
    UNDER HOOD:
    4.6
    DOCH ENGINE
    CP PISTONS
    MANLEY RODS
    SSTEEL CRANK
    STOCK HEADS AND CAMS
    STOCK INTAKE AND THROTTLE BODY
    COMP CAMS VALVE SPRINGS
    CANTON 8 QT. OIL PAN
    FORD MOTOR SPORT DAMPENER
    UPR SOLID MOTOR MOUNTS
    PROCHARGER F-1 SUPERCHARGER WITH COG PULLEYS
    PROCHARGER AIR TO AIR INTERCOOLER
    PROCHARGER POP OFF VALVE
    MEZEIRE ELECTRIC WATER PUMP
    MSD COIL PACKS
    MSD PLUG WIRES
    WELDON FUEL REGULATOR
    CSI ANODIZED OVERFLOW TANK
    MOROSO REMOTE BREATHER TANK
    AFCO ALUMINUM RADIATOR WITH STEEL BRAIDED LINES
    DUAL ELECTRIC FANS
    HURST LINE LOCK
    TRANSMISSION:
    POWERGLIDE BUILT BY GODLEY'S (MOULTRIE, GA)
    HIPSTER PRO TREE TRANSBRAKE
    5000 STALL TORQUE CONVERTER BY ULTIMATE CONVERTER CONCEPTS
    HURST QUARTER STICK SHIFTER
    ADJUSTABLE TRANSBRAKE BUTTON
    J.W. ULTRA BELL
    J.W. FLYWHEEL
    2 TRANSMISSION COOLERS
    MOROSO HEAT SINK COOLER
    STANDARD COOLER WITH FAN
    REAR END ANS SUSPENSION
    8.8 REAREND NARROWED AND TRUED
    C-CLIP ELIMINATORS
    MOSER 31 SPLINE AXELS
    SPOOL
    4:56 GEARS
    ALUMINUM SUPPORT GIRDLE
    AXEL TUBES WELDED TO CENTER SECTION
    STEEDA ADJUSTABLE CONTROL ARMS
    STEEDA SPHERICAL BUSHINGS
    CUSTOM MADE LOWER CONTROL ARMS
    STRANGE ADJUSTABLE SHOCKS
    SHORTENED SPRINGS
    STOCK REAR BRAKES
    STRANGE FRONT BRAKES
    STRANGE MASTER CYLINDER
    FLAMING RIVER STEERING RACK
    QA 1 TUBULAR K-MEMBER
    QA 1 TUBULAR FRONT CONTROL ARMS
    STRANGE ADJUSTABLE STRUTS
    COIL OVER KIT
    CASTER CAMBER PLATES
    LAKEWOOD DRIVESHAFT SAFETY LOOP
    INTERIOR:
    10 POINT CHROMOLY ROLL CAGE
    AUTOMETER PHANTOM WHITEFACED TACH AND GAUGES
    SIMPSON CAMLOCK SAFETY HARNESSES
    KIRKEY ALUMINUM RACING SEAT
    CUSTOM FABRICATED CHROMOLY STEERING COLUMN
    GRANT REMOVABLE STEERING WHEEL
    ELECTRONICS:
    F.A.S.T ECU
    MSD DIS 4 IGNITION BOX
    ELECTRIC WINDOWS
    PAINLESS WIRING HARNESS
    PAINLESS SWITCH BOX WITH FUSED SWITCHES
    WELDON 2035A ELECTRIC FUEL PUMP
    MISC:
    BOGART RACING WHEELS
    UPR STAINLESS STEEL LUG NUTS
    DYNOMAX BULLET MUFFLERS
    MICKEY THOMPSON 28X10.5 ET DRAG SLICKS
    MICKEY THOMPSON ET FRONTS
    OPTIMA RED TOP TRUNK MOUNTED BATTERY
    FLAMING RIVER ELECTRIC CUTOFF SWITCH
    BALLAST TIE DOWNS IN BACK SEAT AND TRUNK.
    BLACK WITH CUSTOM PAINTED FLAMES AND RIPPED CHECKERD FLAG
    bitches aint shit
    Marthasville
    fast
    Indecisive SOB aguynamedpat's Avatar
    In your attic
    Dude, honestly, wtf. Can you make any posts that are more than one ****ing word? All your posts are "nice," or "fast." Stop post whoring the **** like that dude, at least contribute to the thread with MORE than one word.
    This car ever been run at Commerce? It looks familiar. That is a sick setup, good luck with the sale! Im sure someone out there wants to run 9's....
    Public Enemy #1
    i have seen this car run at two fun ford events....that car is NO JOKE! saw it on ebay, looks dam dam dam dam dam dam dam dam dam dam nice!
    pictures dont work for me... sad day.
    slow evo
    pics don't work for me either!
    douglasville,ga
    working for me?
    Pm me the pics and I'll post them, they aren't working for me either.
