Results 1 to 4 of 4
Thread: wiring problem?
    @ballengine ballistic08's Avatar
    Grayson, Georgia
    Default wiring problem?
    well my left sub and my back right speaker dont work. is there somethin connecting the two that will make them both stop working or is it just my wiring loose. any help appreciated
    facebook.com/ballengine
    depends on the setup, is there a rca output on your head unit or is there a hi lo converter on the rear speaker wire? If there is a hi lo converter that is tapped into the wires of the rear speakers then yes there that is the prob. Otherwise it was just happen to go out together.
    Grayson, Georgia
    im not sure, i didnt wire them myself, but that could be the case, i have 2 amps, and all kinda crazy wiring. is it any easy fix or should i just take it somewhere?
    if you know what you are doing when you take a look then do its easy, but if you don't know whats going on othen i would take it somewhere because it could get kind of complicated.
