Results 1 to 40 of 59
Thread: 96-00 Honda civic parts!!!!!!!!!!!
    Arrow 96-00 Honda civic parts!!!!!!!!!!!
    Ok had some random stuff laying around. It came of a 99 Civic Ex check it out. PM me for faster response.
    99 civic EX 5 speed ECU=$80
    Hood latch set=$20
    Alpine speakers all 4 plug and play ( one need the wire soldered back on)=$35
    Electric window regulator (driver side)=$30 (SOLD)
    Drive door handle=$5
    Rear passender truck light metal piece (goes under it)=$5
    Rotors are good just layed around outside=$20
    Have all A/C compenents except the A/C compressor ( imtalking all the lines and condenser inside the chasis everything except the compressor)=$300
    99 civic Ex tac=$80
    Radiator fan=$40
    Stearing wheel pinion thingy )with all the turn signal's attacked)=$50 (SOLD)
    99 silver gas cover (silver)=$5
    Under carrige mount driver=$10
    A/C bracket=$25
    Fuel Filter=$10
    Water thingy that holds water for wipers=$10
    Shift linkage=$50
    Air box=$40
    99 cruise control modual=$50
    Front hubs=$50 (for both)
    Front (both) springs with shock's=$40
    Calipers (both) good pad life as you can see=$50
    OBD2 D series Alternator=$50
    OBD2 interior harnes ( mean all incleding the engine bay fuse box atached)=$150
    Front bumper support with styraphone support=$40
    Trunk had litttle bent at botton left corner=$30
    99 tail light only set of three 4th was broken=$35 (SOLD)
