Results 1 to 15 of 15
Thread: H23 OBX Intake manifold
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    Default H23 OBX Intake manifold
    Just wandering has anyone else bought an OBX intake manifold? I have a prelude with an h23, got the manifold in hand and realized its missing alot of ****. Not to mention its blocking my coolant pipe that comes from the head and back into the thermostat. I'll get pics up as soon as possible to show what I mean. It also blocks the EGR, IACV, and has no place to mount the throttle cable bracket. Any Ideas.
    Fast+Cheap= Not Reliable
    Cheap+Reliable=Not Fast
    Fast+Reliable=Not Cheap
    THE DARK LUDE SPEAKS
    the county
    if you are running all motor, its better to run the stock manifold. the bigger aftermarket one holds a lot of air but it doesn't do anything till you reach the higher rpm range. you have to have a lot of air flow going through the manifold for it to work, if not then its just holding air, which is why it works better when using forced induction.
    In the Darkness
    Oh ok. Preciate it. But I still need help with the other problems with the manifold in order to use it.
    murdahrin dem Blood-Claat!
    Dakilla sell that ****... it's not worth it. port your stock manifold and remove the butterflies. it'll be like having a euro r mani. don't waste your time with that...
    h23 intake manifold is the same as h22, so sell that obx trash and get a euro r manifold
    About to approach beast mode
    just die in a fire for even considering an OBX for an H23. Just use the Euro R or possible the BlackTrax. WTF they crack so easily basically a knock off of Venom. At most Skunk is not bad.
    nvm.....
    Kennesaw, GA
    skunk 2
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    the county
    Quote Originally Posted by Ludester
    In the Darkness
    tHE BOLT PATTERNS ARE DIFFERENT BETWEEN THE H22 AND THE H23.
    if your h23 intake manifold says p13 on it, which i am sure it does. then they are the same. check it out then hit me back.
    In the Darkness
    On which section? It has three parts to it. I'm saying the bolt pattern isn't the same. Not the plenum or the secondary runners.
    bolt patterns are different. the only thing the h23 and h22 stock intake manifold have in common are the butterflies. Hence why you might see p13 on it. other than that they don't bolt up.
    In the Darkness
    Thats what I've been sayin. But I found out theres an adapter plate that someone made to fit an h22 manifold on an h23. Anyone heard of it. If so can you direct to with a link or something.
    search on honda-tech I think the guy who made it is on there.... I still don't think it's worth it...
