Results 1 to 40 of 56
Thread: Best SOHC to boost?
    Your Moms Moderattor
    pleasant hill
    Default Best SOHC to boost?
    Just out of curiousity, which honda SOHC engine responds best to low levels of boost? 8-9psi? With out any building what so ever, on a stock motor with an alluminum head gasket.
    Quote Originally Posted by theprofiteer
    This would have to be the Y8.
    pleasant hill
    how does it handle it? Is it worth it, and would it be reliable enough for a DD?
    How would the gas millage suffer as a result?
    What about a Z6 block with a Y8 Head?
    really I am just trying to see if the civic has DD potential and still hold its wieght agianst some of the more meaty four bangers.
    MEGATRON 112480's Avatar
    Mobile,AL
    Not Y8 but a full D16Z6 all the way!!! Just stay under 250whp for a RELIABLE DD D-series. Trust me I know! I made [email protected] and 315whp@18psi on a STOCK cam on my FULLY built D16Z6 before she went boom
    Beat a 450whp GT mustang(on W.G;14.75psi) a new Lotus Elise on W.G(by 4 car lengths!!!!! in third gear alone) a 2007 600rr on 18psi, a 2007 M3(modded) on W.G by 3 lengths and a Porsche Carrera on W.G by 5 lengths but it wasn't a turbo carrera.
    This was done in my 92 Vx hatch and for now going Ls/Vtec turbo and then FULLY built K20a2 turbo!!!
    EBTEC
    EMMINO BUILT
    Allmotor K EK Hatch Coming Soon.....
    single cam f series. nice iron sleeves, make 250ish at 10psi with same torque
    Kennesaw, GA
    Yeah i would definitly have to say F series motors. very tourqey
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    I GOT IT!
    Jan 2003
    Lithonia, GA
    F22 FTW
    Hybridaccord
    if you're wanting to stick with a d-series you already have then any would be fine for 8-9psi on most turbos. the z6 with a y8 intake manifold would be better if that's what you have.
    Norfolk, VA
    i think the y8 would be the best choice.
    <---Click it.
    z6 . . . but thats just me
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    f22 all-day
    N/A>>><<<BOOST
    At Home
    F Series Bitches...
    Jonesboro/Stockbridge
    f series but if you wanna stick d series. the z6 with a y8 manifold.
    At Home
    Its interesting how everyone thinks the Accord is a piece of crap but then it is the best motor option to boost...
    Quote Originally Posted by WhiteAccord
    well they said SOHC's only lol, if they said any motor most would probably say h22 or h23
    Kennesaw, GA
    H series on stock blocks suck for boost. 5psi on stock block at best because of the FRM sleevs. thats good for about 5psi MAYBE
    OF*C
    Kennesaw, GA
    F series > all. My buddies boosted SOHC F22 was good for 10psi DAILY, about 220hp and 290tq on a good tune Plus gas mileage didnt suffer much unless he was in boost all the time
    OF*C
    Gainesville
    D series and they are really cheap to pick up if you blow it
    Gainesville
    actally y8 blows or the head anyways from what i have heard. get a d16y7 block and put a z6 or zc head on it then boost
    At Home
    Nay not even the H22 or H23 makes great power with just a slap on turbo kit.
    Best motor, stock would be the F series.
    But then if its any motor, 2JZ.
    Top Secret Build TopNotchEG9's Avatar
    45 min from the A
    the D16Z6 or the JDM D15B are the BEST to boost...the Y8 isn't that good to boost because of the oil pump...
    My choice is the y8
    ZC all the way with a D16y8 intake manifold!
    Gainesville
    good point^
    Texas
    Quote Originally Posted by TopNotchEG9
    D15b... Im on my third, Ive blown two of them up. At 10 PSI. Im currently. Building a D16a6 Block with a Z6 Head. Ihave heard that the A6 bottom ends are stronger. We will see. I have heard alot of good things on the A6. Z6 are good but. Im going to try somethin diff.
    Atl
    f series, d series any way you choose the **** is going to be ridin!!!!!
    the accord is not the motor
    Kennesaw, GA
    Quote Originally Posted by The Youngn
    but it comes with said motor
    OF*C
    At Home
    duh... cmon mang.. use common sense.
    Kennesaw, GA
    i like mah new sig. looks dangerous :-D
    OF*C
    pleasant hill
    the f series codes, how do they code, what would the code for the vtec block be, and what would the code for the non-vtec be?
    Kennesaw, GA
    f22b1 is vtec, b2 is non vtec
    OF*C
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    dohc???
    if so, you cant swap intake manifolds on dohc zcs like that
    Senior Member BlkCD5's Avatar
    well, you accord owners know im pro F-series for boost.
    pleasant hill
    Can any body link me to a how to write up on installing a turbo kit on a Y8, and maybe some tips on what would be the best cost effective items to use in a build.
    Cause I have a y8 but it needs a rebuild anyway, so I figure I might as well rebuild it for turbo.
    stockbridge
    dohc???
    there is a dual cam zc, and a single cam zc.
    z6 ftw. imo.
    f22 may be good, but in a very heavy car, it will be pwnt by a turbo d in a hatch. stock vs stock.
    Kennesaw, GA
    z6 ftw. imo.
    better check that. 5th gen body doesnt weigh as much as you think. Power and torque that a turbo on this block puts out defninitly helps the power/weight ratio. curb weight on this thing is 2800 and change w/ a driver. and i plan on stripping the interior and replacing the fronts with some brides or recaros. The hatch may be about 2000. NE ways lemme finish my setup and you find someone i can run. boosted F series accords are ALOT faster than you think
    OF*C
    stockbridge
    Quote Originally Posted by blank cd
    good deal. no drama.
    make sure u stay in touch. i am positive ill find someone with a stock turbo d. if not, ill have one ( also stock). 4dr eg.
    Kennesaw, GA
    when you say stock turbo, you mean stock internals correct?
    OF*C
    stockbridge
    yes. what i RLY meant was COMPLETELY STOCK. no upgraded injectors pump, intake manifold.
    taht is what i will be.
    stock injectors/ pump.
    only a small turbo, 7 psi, no intercooler.
    but im pretty sure that is not how u will be so what i think the paramiters should be is
    upgraded fp, and injectors ok.
    but nothing crazy like fuel rail, fpr, intake manny, tb upgrade,. those things add up when put together.
