Results 1 to 16 of 16
Thread: dumb question.valve clearence w/ crower
    tink tink btldzc's Avatar
    COG
    Default dumb question.valve clearence w/ crower
    i pretty sure i know the answer..
    i just put crower stage two cams in w/ supertech valve springs and retainers..it wont idel at all..but it will rev all way the to 9 grand... i havnt adjusted the valves yet..it should idle after i adjust the valves..whats the valve clearences for a gsr?
    IN LOVING MEMORY OF GAI
    SEE YOU WHEN I GET THERE BOIE!
    3/8/75 TO 4/18/05
    Duluth, G-nett
    if your valves clearance are off a little, it should still idle. clearance is .007 IN and .008 for exhaust. I ran .006 IN and .007 exhaust on my boosted gsr.
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by btldzc
    so....before asking any questions or doing any diagnostic work to the car...you decided to rev it to 9k rpm? hmmm that sounds logical.
    The Carbon Fibered R6
    for once your dumb ass said something right
    Quote Originally Posted by drmcivicsi
    lol. i just like to fùck around on here. but i'm kinda in the mood for seriousness lately.
    COG
    whats not logical about it? Just because it wont idle I cant rev it to 9k? Whats the big deal? Let me know what was not logical about what I did? I was trying to point out that it runs correctly. It just wont idle.
    3/8/75 TO 4/18/05
    COG
    Quote Originally Posted by Vuongy_Dong
    I was thinking maybe the valves springs are to tight and will not let the valves open sufficintly for idleing. There car is running fine after about 2 grand. I can drive it around just wont stay on at a red light. It will lope then die.
    3/8/75 TO 4/18/05
    IA Member jbhondatech's Avatar
    more than likely the car needs to be leaned out at idle much like the Skunk2 pro1's
    and if this is the case then it is safe to say that your A/F's are off in other areas making it very irresponsible to go into vtec not to mention reving to 9k.
    COG
    AHHH..okay...what if the valves didnt seat properly.
    3/8/75 TO 4/18/05
    ^^^ PM mr kidd
    valves should always be adj after installing cams, but your problem is it's not tuned for those cams.
    it doesnt run correctly if it doesnt idle....
    EF SQUAD FTMFW!!!!
    your moms house
    check your cam timing the valve lash isn't going to make your car not idle. those cams idle just like stock because the primaries are like a stock gsr or type r so it shouldn't need to be leaned out that much if any when they should be pulling around the same amount of vacume at idle. so i would go back and check your work just to make sure everything is right
    COG
    Im going to re check the cam timing..it may be wrong
    3/8/75 TO 4/18/05
    nothing is going to work but If you get it TUNED what does these NOOBS think when they do **** like this, that its going to run bad ass, with out getting it tuned, YOUR ECU is not knowing what to do an your A/F is well the hell off , Call scotty an get it tuned Problem FIXED hope this helps
    COG
    whos a noob?
    3/8/75 TO 4/18/05
