Thread: motor mounts VS inserts
    college park
    Default motor mounts VS inserts
    im looking for some mounts for my car and want to know what if i should get mounts or just the inserts the car is a dc integra and a b series is going in it.
    now with LSD
    mount inserts are way cheaper and make your stock mounts stronger, aftermarket mounts are made stronger and specifcally designed for whatever they say their made for
    SuperLIGHT SUNfire.. madking411's Avatar
    Norcross
    sooo....
    inserts = goood.....
    mounts = GREAT! if you need some specificness and function added along with the extra strength...
    \\\ATLANTA~ATNALTA///
    college park
    ok so i could just buy the inserts then? it has a ls in it now but im putting a new ls in it later so nothing fancy
    now with LSD
    Jonesboro/Stockbridge
    Well, you can get stronger mounts that gets your power to the ground more because the stock mounts rock too much....It all depends on what you want. If you like feeling your engine idle and whole car rock but get power to the grounds then get the mounts...
    well personally i say use stock integra mounts as they are cheaper, easier to find, and easier to source n get when you break one . . unless you want to spend the extra money for the almighty aftermarket mounts
    college park
    any suggestions on who to use such as a company i was thinking avid racing
    now with LSD
