Results 1 to 11 of 11
Thread: WTF is wrong with this?!?
    IA Member GTP_Power!!!'s Avatar
    Default WTF is wrong with this?!?
    My system was popping the fuse in the power wire and when i changed it the third time it made this pop and now evertime i hook the power wire to the amp it sparks big time so i have it all unhooked right now. Does anyone know whats up?
    I have a Pontiac. Later, QD.
    i have a nissan
    Hiram, GA
    you have a short someplace.
    Are you disconnecting the power wire from the amp, then putting the new fuse in, then trying to connect the wire again? If so, you are just looking to fry your amp.
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    Quote Originally Posted by GTP_Power!!!
    check your ground wire, make sure its making good contact and not moving like at all.
    I GOT IT!
    Jan 2003
    Lithonia, GA
    either the power wire is grounding out somewhere against some metal or the amp is toast which can cause it to happen also/
    Hybridaccord
    no accord
    alpharetta
    your amp is prolly toast
    RESIZE PIC PLEASE
    First off it should not be sparking when you connect it to your amp. you should have disconnected the negative on the battery before disconnecting or connecting anything to the amp. Secondly you have a short or too small of a fuse in there.
    Certified Gearhead vTeC's Avatar
    Columbus, GA
    I'll agree with the above posts:
    1. Power wire is shorting out somewhere
    2. Ground wire isn't grounding properly
    3. Amp may be fried, which could cause the fuse to blow as well, according to what exactly happen burned on it.
    WindScarrrr?? bware113's Avatar
    Marietta, GA
    I think the amp is gone...
    Under your bed.
    you may have a loose ground wire...
