Results 1 to 32 of 32
Thread: for all the boost heads out there?????
    Total Insanity helcat17's Avatar
    macon
    Question for all the boost heads out there?????
    i have a boosted 94 integra RS i want to know what is safe boost to run on a stock b18b1 i have 450cc DSM,it was tuned by "mainstreem performance thanks scotty" at 5.5 psi but im wanting to know what i could take it up too safely by maybe changing head gasket and maybe going to ARP head studs and A RETUNE just looking for some ideas thanks guys
    BOOSTED GSR/HYBRID
    ON THE TRACK
    10 or 11 scotty did mine to and im all stock bolts and hg 270 on 560 dsm inj.
    macon
    and im talking about with it being retuned thanx vancem3m3
    Use ARP rod bolts & ARP head studs!
    macon
    i know theres more people out there with good thoughts!!
    'Round These Parts
    Sounds like you want to push your limits - where you are now is safe!
    You just want someone to post 14psi don't you?
    I bet your B18b1 engine has over 150k on it right?
    build it before you break it!
    Leisa and S. 4 Life NM?
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    Good advice, but not quite as fun as romping on it one time and hearing 'ping ping ping ping BOOM'
    Seriously, if it's tuned for where you're at now, don't mess with it.
    02 WRX patrick4588's Avatar
    warner robins
    psi really doesnt mean anything. a stock ls is reliable up to about 250whp. you can definitely push a lot more, but not reliably. on a 57 trim turbo, 250whp is about 10psi. just make sure to re tune if you up the boost. DO NOT UP THE BOOST AND NOT GET A RE TUNE
    GCO Member
    NRA Member
    macon
    im not looking to get bashed just to get some opinions and no my engine dose not have that many miles on it and no im not looking for someone to tell me 14 psi if its not true im simply looking for poeple that know a lil bit more about the motor than i do to let me know what they think if you feal like bashing me then its simple DONT POST!!! o and yes im wanting to push my limits a lil bit if i didnt i would have left it N/A just wanting to know what the stock motor can handle and if you had read the post it said that i was planing on geting it tuned AGIN at what ever boost i decide to run soo if your not going to answere the question i asked how about not posting at all
    'Round These Parts
    Quote Originally Posted by helcat17
    Tough love is the best way to get the point across!
    macon
    thanks patrick thats the info im looking for
    'Round These Parts
    Oh I don't get a thanks man?
    Ellenwood
    I didn't see anyone bashing you. You were actually kind of unclear in your OP...you made it seem like you wanted to turn the boost up without a retune. You didn't ask what the MAXIMUM your LS would hold.
    Either way, glad you got the info you were looking for.
    macon
    OP edited to say with retune sorry if i was unclear befor
    NAwasBEST NAG2I's Avatar
    metro
    id say go with the arp head studs and you would be fairly safe
    the main problem i see with peoples boosted stock ls's are lifting the head due to stock head bolts.
    ATL_DA_Squad #3
    STREET<3LOVE
    macon
    thanks nag2i but what psi have you seen the head lifting hapening at?
    I wouldnt do more than 10psi as it sits. The b-series weak ringlands would probably break before the head would lift.
    macon
    i think im gona aim around 9-10 psi and i have a 57 trim but im going to change the head studs anyway and allsoo the head gasket since im going to be in there if anyone has an idea on a good gasket let me know thanks everyone
    macon
    im allsoo going to start looking for some internals im considering eagle rods and wesco pistons 8.5 comp. if anyone has better ideas let me in on that too
    metro
    everything you would probably want to know and more is in this thread
    http://www.honda-tech.com/zerothread/1323059
    i will look too about the head lifting i mentioned
    ATL_DA_Squad #3
    STREET<3LOVE
    BK ALL DAY
    y dont u just build it instead of turning da boost up... makes no sense taking da head off for some headstuds and head gasket... **** u got it apart that far u might ass well go for it...
    GECKO SQUAD MEMBER
    MSS RACING REPRESENTA.....
    the saga continues....
    macon
    Quote Originally Posted by Da_unknown
    lol cause i dont got a grand to throw down on it at this time for internals i colect parts piece by piece then when i get it all together i take a weekend and put it all on or in lol but if your wanting to pay for it im taking offers
    BK ALL DAY
    lol...am good homie....
    GECKO SQUAD MEMBER
    warner robins
    i used cp pistons in my build; so thats what i would go with. also, there is no need to lower the compression. stick with stock or around 9:1. oh and go with a oem head gasket. if you bore it out, then get a golden eagle; they use stock honda ones and modify the bore.
    GCO Member
    NRA Member
    macon
    all the info is great keep it comin
    140 on one wheel
    columbus, ga
    i see so many 300whp boosted ls's on h-t it's not funny i say push it somewhere around there.
    I wouldnt change a thing except the map sensor and a 10lb
    spring for your wg. B18bs are a dime a dozen. Just build a
    spare block and you have no downtime. just my 2cents.
    Although there are a lot of "claimed" 300 WHP B18A/B (LS), I don't remember seeing anyone locally with a 300 or even high 200 WHP Turbo-LS driving around ... reliably.
    Banned lsxtreme's Avatar
    wat size turbo..??
    but thought i let ya know on my scenario.. i was on a little itty bitty turbo with a VW t25 turbo.. and i maxx'd it out @ 13lbs all stock internal, nothing aftermarket on it .. and i daily drive it ............... from cobb2gwineett everything day .. i only dawg on it a once/twice, no problem i'd say.. depending on ur turbo .. if it's small one dawg it mann your not going to hurt it.. unless your a bigg baller t3/t4 or higher.. leave it be..
    JDM TYTE AnthonyF's Avatar
    "boost head"? i'm a junkie. lol.
    i'd say about 7-10 with a good tune
    The Carbon Fibered R6
    "big $hit poppin"
    in the slums where killas get hung
    Quote Originally Posted by NAG2I
    interesting
    140 on one wheel
    columbus, ga
    Quote Originally Posted by KevinT707
    @$@$@$@$ the car importmyth01 drove made high 200's and has had about 9 owners beat on it since him and still runs 12's easily. It even seen some 18psi momments. And some dude just sold a del sol that had been boosting 20psi for like two years on the stock motor.
