Results 1 to 2 of 2
Thread: What will I need??
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    Default What will I need??
    I am doing the 1jz swap on my 91 MKIII, what all will I need??
    I know I have to extend the harness but I am having a local shop do that (Vision Performance)
    LMK YO!
    REPS...
    Quote Originally Posted by Brian*
    LMK YO!
    REPS...
    If you purchace the entire clip then you will have everything you need.. And when (vision) extends the wire harness make sure they have the right Ecu Pinouts so it will all work right.. It is not as simple as extending.. there is alot of re routeing of the wire's to change pinout location's you will also need to get teh MSD box so you can get your Tack to work properly.. (had to do it on mine aswell..) The motor mounts if need be replaced are the same as the 91 and up 7mgte..(fluid mount's)... It's a **** load of work but worth. it....
    Good luck with it...
