Results 1 to 13 of 13
Thread: WTT:p28 ECU
    Default WTT:p28 ECU
    Ok to start of I have a p28 ECU in perfect working order, but im running a SOHC VTEC with B16 program in the p28. Its was chipped for turbo plans, but returned to basic B16 pragram. I need a Virgin p28 if anyone has one it. The reason why I want to trade is bc Im geting a engine light and I know there is nothing wrong with the engine bc I plugged a stock ecu to it and ran fine no light's. So this ECU I have is perfect for that b16 of your....
    on an obd1 chipped ecu, to go back to the original ecu configuration, just cut the j1 jumper above the chip.
    Quote Originally Posted by b16acrx
    Now why would I do that... if I could help some one out with a already chipped B16 ECU?
    Certified Gearhead lsi-crvtec's Avatar
    i have one
    Bump
    who knows.
    i may have a friend who needs this.... buddy is runnin a gsr with a stock p28 computer. what is the rev limit on it?
    Quote Originally Posted by thinkskater
    I have not taken it past 7rpm might go more than that though. Everything works well just runs ****ty on the Y8. All I know it was chipped with uberdata for boost on B16 then chipped back to B16 specs.
    Bump
    Unknown
    does it still have the uberdata chip? could it be reprogrammed?
    Quote Originally Posted by feeshatl
    It has some kind of chip could not tell you.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    I may be willing to trade you my unchipped USDM p30 for your chipped p28. A friend of mines tried it in his d15b swap rex and it ran it perfect (with no check engine light). If you want to meet up one day and do a test run LMK and we can do that
    I need p28.
    Bump
