Results 1 to 30 of 30
Thread: Kill the Lexus vs BMW beef. Supra 2jz in 5 series!!!!
    Everywhere
    Exclamation Kill the Lexus vs BMW beef. Supra 2jz in 5 series!!!!
    This car found in S. Florida.
    Vossen CV3 20x9 & 20x10.5
    Wow! what a clean swap.
    Dunwoody
    i wouldnt call that a clean swap i would call it interesting as i have never seen it done before but that **** is definitely a mess. but in the same breath very interesting
    Apr 2003
    Acworth/Kennsaw
    Why? Did the blow the last motor, and could'nt afford another bmw motor?
    Dunwoody
    ^something tells me that a 2jz swap in a bimmer is going to cost more than just replacing the factory motor
    st00pified nightracer's Avatar
    I-75
    Eh, that 2JZ is a whole hell of a lot easier and cheaper to make 800whp with than the motor that came out of it. The ///M5 V8 would have made 1100whp or so but It'd be so damn expensive and a pain to work on.
    /////////////// haxing ///////////////
    Apr 2003
    Acworth/Kennsaw
    you dont know what your talking about.
    Dunwoody
    ^your right i don't but at the same time consider this...........it costs what 10k to do the 240 2jz swap and thats a much simpler car to deal with than a bimmer what do you think it costs to put in a factory bmw motor again i am willing to bet its less
    Apr 2003
    Acworth/Kennsaw
    Do some research.
    Apr 2003
    wow, that's wack. Interesting swap nevertheless.
    Marietta, Ga
    That's terrible, I'll never get why people like to put crazy different motors in cars they don't belong in. But props to those who do it and get it right anyway.
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    $10k????
    ☠Young Harris☠
    ****ing sic...
    ☠Young Harris☠
    awe.. we can't cuss anymore??? boo
    Duluth, GA
    There was a 2jz Mercedes in Japan, comparable to that one you have up there.
    http://www.youtube.com/watch?v=MPodp9DOQbQ
    IA IS FOR FAGS coolcat's Avatar
    FAGGOTS
    Wow, that's bad as hell. +1 for the good find.
    BUY MY NEW BOOK! ITS CALLED, IF YOU LIKE IMPORTANTLANTA THERE'S A STRONG CHANCE YOU'RE A FAGGOT
    If you follow the link and look to side you get a hold bunch of different 2jz swaps.
    'Round These Parts
    i don't respect that swap!
    Leisa and S. 4 Life NM?
    Dunwoody
    Quote Originally Posted by Brian*
    $10k????
    yes sir go into mainstreams section of IA and it says done out the door price on a s14 is 10k. now can you see why i say its probably a **** ton more on a m5 if thats truly what it is and how its probably less expensive to just put in a new motr instead of...........engineering motor mounts, trying to figure out how to make all the stock stuff work with the new motor and ecu, etc,etc,etc.
    Buslengths behind you
    x2....as hard to belive i respect that less than the V8 swaps into RX-7s
    'Round These Parts
    Even if the swapped was super clean, it seems way to inconsistent.
    Class issue I guess.
    I'm a carracist!
    2jz gte are also a common swap in the M3's
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    cool i guess imo that was a waste but what ever. C and Y in japan does some of the sickest swaps in cars I have ever see. check this out http://www.youtube.com/watch?v=dnlgs04LXGI
    N/A>>><<<BOOST
    ☠Young Harris☠
    umm ok, mainstream may charge 10k for a ****ing 2jz swap but do it yourself and dont be a panzy... alot cheaper
    NICK'S AUTO REPAIR esiatlanta's Avatar
    sugarhill
    damn....thats nasty dawgg....
    in your nightmares
    how can you argue with one of the most legendary motors mixed with one of the best handling chassis ever made? the vette motor is way stronger, lighter and 10x more reliable than a boosted rotary. I love rotarys but they are delicate as hell.
    N/A>>><<<BOOST
    Dunwoody
    Quote Originally Posted by ruffian
    because the reason its the best handling chassis is because when they put the motor in its all part of the equation of weight distribution and handling. so when you take out the motor and put in a different motor it ****s with the whole balence of the car granted i believe that most sr swapped miatas actually help the weight distribution i highly doubt pulling a V8 and dropping a straight 6 is going to help the chassis balence
    So your telling me your comfortable pulling out a Bmw motor and dropping in a 2JZ engineering and fabricating the engine and transmission mounts and then on top of all this figuring out a way to make the motor run without losing all the bmw options?
    Rock the 40oz GTScoob's Avatar
    GA Tech
    I guess the haters in here have never looked at how much BMWs cost to mod. Most aftermarket turbo or supercharger kits are all ~$10K. Granted they are all engineered to look completely OEM when the hood is popped open you're still stuck with an NA base motor.
    Why not spend the money on a better factory turbocharged motor with much more potential and just swap in a 2JZ or RB?
    02 WRX Sport Wagon
    in your nightmares
    [QUOTE=redGT]because the reason its the best handling chassis is because when they put the motor in its all part of the equation of weight distribution and handling. so when you take out the motor and put in a different motor it ****s with the whole balence of the car granted i believe that most sr swapped miatas actually help the weight distribution i highly doubt pulling a V8 and dropping a straight 6 is going to help the chassis balance
    QUOTE]I'm talking about weight. the all aluminium chevy 350 is lighter than all of the plumbing and turbo+motor associated with the rotary. You have got to know that the less weight you are push/pulling around, the better the car will handle. the chevy has 3x the torque of a rotary and you are pushing a lighter car.
    N/A>>><<<BOOST
