Thread: Since theres alot of ppl here..
    ALL CAPS JITB's Avatar
    Default Since theres alot of ppl here..
    I can get a quick response. how would i be able to tell if the bearings inside a cv axle are worn? Would the car shake /wobble real bad ? or what? the boots arent busted at all. My car jsut wobbles reaaaal bad and its undriveable, i replaced the bad axle but it still does it jsut not as bad. So could both of them been bad?
    wrong forum i know..just need a quick response
    Drama Free Queen T-Mo Goodie's Avatar
    are you sure its not your wheel bearings/hub assembly???
    '06 Infiniti G35
    '96 Honda Prelude (project)
    www.twitter.com/tmogoodie
    My car uses sealed bearing assemblies. And i wouldnt even know where to began on repacking them..
    Cav-E-R's Lesbian Seagull Kristi's Avatar
    Lawrenceville, GA
    i'd help, but i dont know shit
    Seen it all, done it all, can't remember most of it!
    Myspace
    Facebook
    BAAAH
    ZERO sir2hb's Avatar
    L.B.C (little bitty calhoun)
    it proably the bearings if the cv bad it will pop when you turn
    I never won any spelling bees
    Horsepower looks good on paper, Torque wins races.
    Because I eat RICE RiceBoy's Avatar
    to check bearings. jack up your car and wiggle the tires with your hand. If it moves, then it is your bearings. to check for you cv axles, drives in circle and if the cv axles are bad it would make sound...
    while your car is up. check the tires for bad spot also.
